2000 ET4
2000 ET4
hello, have heard you need all sort of tools to do this but had planned on using an allen key, a small spanner and a tyre iron, is this possible/
@bluebuddha avatar
Kitted ET4.
@bluebuddha avatar
Kitted ET4.
Re: et4 rear wheel removal
The first thing you'll need to do is remove the exhaust to access the rear tire.
Check out "youtube", and search, removing rear tire on an LX.
A guy does a demo of the process and a recap of all the tools you'll need.
Best of luck.
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
@dougl avatar
El Macho
Vespa GTS 310
El Macho
@dougl avatar
Vespa GTS 310
No. You'll need allen keys to remove the two exhasut mounting bolts. 10mm spanner/socket/wobble extension to get the exhaust header bolts off. A cable tie to lock the rear brake on. A breaker bar with a (?)24mm socket to remove the wheel nut, and a pair of needle nose pliers to remove the split pin on the nut.
Oh and you'll need a big, fat torque wrench to put it all together again. You really do need the right tools.
2000 ET4
2000 ET4
have done it, was a bit easier than i thought, excpt getting the exhaust back on by myself. ended up buying a basic car tool/socket set from halfords and some other bits, didnt use a torque wrench to put the wheel back on, just tightened it as hard as poss. seems ok.... thanks everyone for the advice, the haynes manual i got tells you what to do but not what tools to use!
ET4 150
ET4 150
Cleaning hub splines
super-fly wrote:
http://www.youtube.com/watch?v=rqvy0XpPtqY
So, I had never changed a vespa tire before and looked up the utube presentation. I was shocked to see a recommendation to use antiseize paste on the spindle. Not a good idea. Those are splines that the hub and spindle use to mate together. Antiseize is NOT robust enough. Honda make a great grease specifically designed for this. I use a BMW product called Starbaugs No. 10. My little ET4 150 is 5 years old, has had at least one tire change before I bought it; there was not a smidgen of grease on the splines. They are now properly greased. I of course use antiseize on bolts that I wish to be able to undo later, but splines need a good tacky grease that protects the splines for a long life.
[ Time: 0.0208s ][ Queries: 3 (0.0021s) ][ live ][ 343 ][ ThingOne ]
