I have a 2007 Vespa 250 GTS. I drive on the crappy roads of manhattan. Seems that it bottoms out a lot on some of the rough patches when only riding 1up. I weigh 200 lbs. I have the shocks set to the 3rd tightest setting...Does this sound right. Seems to do the same thing on any bump on the highway 2up (about 320lbs riding). Could my suspension be shot from 1 1/2 years of NYC driving?
Thanks!
Rehabdo
@genie avatar
Gobshite Shiva
Gobshite Shiva
@genie avatar
your shocks could very well be knackered that early - i've seen the state of the roads in NYC and it wouldn't surprise me.
@benito avatar
@benito avatar
I'd have to agree with Genie, with your weight you really shouldn't be bottoming out unless you are going really fast over a bump or big pot hole. You might want to compare it to a newer scooter with the same settings to find out.
2005 GT 200
2005 GT 200
bump it to setting 4 and see if that solves it.
@zagato avatar
Vespa GTV 250ie
@zagato avatar
Vespa GTV 250ie
I think there are only 3 settings on the rear shock. As stated earlier, a 200lb rider shouldn't be bottoming out.
Best if you took it to the dealer.
@benito avatar
@benito avatar
There are four settings on the rear suspension of a GTS as there are for the GT, LX and S too.
2005 GT 200
2005 GT 200
yes...Benito is correct (mine is set on 4)
@elvispa avatar
GTS 300
@elvispa avatar
GTS 300
Re: Bottoming out on Vespa 250?
I must disagree, to some degree, with my forum fellows:
1. I have a new GTS 300, my weight is 200+ lbs., and on certain roadways I definitely bottom out. There is only a limited amount of suspension travel, and especially if we are talking about some continuous undulating road surface that gets the bike going up and down a bit before the big whack, you can for sure bottom it.
2. This is NOT to say that your shocks aren't knackered--they may well be.
3. Fooling around with the pre-load, on most cheap shocks like this, does NOT give you more energy absorbing ability. In fact, it probably takes a tad away as you are pre-compressing the springs--not that it matters much.
Thanks!
Rehabdo
@ken_photo avatar
'07 Vespa GTS250ie
@ken_photo avatar
'07 Vespa GTS250ie
I riden two-up in Manhattan with my GTS for 3 years (setting 3 on shocks) and don't bottom out. Have a dealer check out your shocks.
'08 Piaggio Fly 150
'08 Piaggio Fly 150
And don't forget to check your tire pressures, front and back. Even being low a pound or two can make a difference.
@peter_evans avatar
Vespa 300GTSie Super, 1978 Honda cb750k
@peter_evans avatar
My 300 bottoms out too...
I'm ~210 lbs ... roads are crap, I ride fast.
I am on the 3rd setting on the shocks.
Maybe I should go to 4?
@zagato avatar
Vespa GTV 250ie
@zagato avatar
Vespa GTV 250ie
Sorry, you guys are right. There are 4 settings.
2005 GT 200
2005 GT 200
add back any top case/contents to your weight as well.......
@rgconner avatar
GTS250
@rgconner avatar
GTS250
I would recommend the Jettin bushings. Adds some road buzz, but definitely helps with the bottoming out.
@elvispa avatar
GTS 300
@elvispa avatar
GTS 300
Hey! what are the Jettin Bushings?
and more to the point what do they do??
@benito avatar
@benito avatar
The standard bushings are fairly rubbery and allow a fair amount of lateral play when going over bumps or pot holes. As a result of the lateral play I found that with the OEM bushing going over a bump/pothole you would almost not come out of it going in the same direction. The Jettin rear suspension bushings are stiffer polyurethane and do not allow this lateral play. Thus coming out of a pothole I feel that the bike continues to track true and comes out of the pothole in the same direction as when entered. I do not find that it stiffens the ride, nor is it supposed to.
@stoker avatar
vespa gts 250, '66 gt210,'63 gl 210, t5 mil. gs180
@stoker avatar
i have been riding around for years bottoming out, theres nothing wrong with my shocks i just like riding with my bottom out Laughing emoticon
@ifixjets avatar
01 ET2 - 01 ET4 -- 05 GT200L / 05 PX150 / 23 Triumph Bonneville T-120 Chrome Edition / 23 Triumph Scrambler 900 / 23 Triumph Tiger 1200 GT Explorer / 24 Honda Trail 125
@ifixjets avatar
I am 265+lbs and I have never bottomed out my GT200. Shocks are set at the 4th setting.
@turkman avatar
2009 GTV 250
@turkman avatar
2009 GTV 250
New Shocks
2-up were were bottoming out really bad, so after 36,000 miles I replaced the rear shocks on the GTS with OEM ones (a little over $200.00, cheap for shocks). Rode to Amerivespa and back through NV, was better but we could still bottom out, sometimes. Have to say besides being 2-up we were probably over loaded with gear. Was interesting to hear that the Jettin rear suspension bushings could help, will order a pair today.
Have tried the Bitubo shocks front & rear, they were to stiff for me, but did make the scooter feel more planted on the road and I could set the rear so there was no bottoming out (not even 2-up).
@jlb avatar
2007 Vespa GTS 250ie
@jlb avatar
Benito, let me just add to what you said, which is correct.
The urethene is a higher durometer number than the stock bushings. Durometer has a scale from 1 to 100 being the highest. It measures a materials ability to resist permanent indentation, and they have a number of different scales for different materials, like steel, rubber and urethane, etc. At 100, you would expect virtually zero flex at all, and they would be rock hard. The Jettin bushing has a durometer of 90, which is pretty stiff.
Now, to veer totally off topic: I learned about urethane durometer ratings back when I was a semi-pro skateboarder in the late 1970s, and we had softer durometer wheels like the red Kryptonics that rode smoothly (and were very fast) and would flex, but were so soft that they would also chip. Those were a durometer of about 75-78, as recall. The blue Kryptonics were a higher durometer in the 80s, and the green were the highest near 90. I eventually was sponsored by UFO wheels for a time, and they were rock hard well over 90 durometer.
There was also a durometer rating for the bushings in the trucks of the skateboard. We all rode Bennett trucks in the beginning, but the rubber was too soft so everybody would swap out for Tracker trucks bushings, and we eventually switched to Tracker trucks, and then Independants, which I think is still one of the leaders today.
I found some of my old boards in my parent's garage a few months ago and brought them home with me.
One of my first hand made boards. Before this I used cut down water skis they tossed out from Cypress Gradens. After this board I had a Logan Earth Ski.
One of my early Gordon and Smith decks. That one had Bennett trucks and Road Rider 4 wheels, and later OJs.
This was one of my favs. I had it set up with Trackers and UFOs, and I toured out in California at Upland and Spring Valley.
My last board was a Caster with Independents and Green Kyptonics. I probably had 25 boards, but they are all gone but these.
Sorry for the off-topic post, but urethane and durometer are words that bring back a flood of great memories for me.
@benito avatar
@benito avatar
Re: New Shocks
I don't honestly think that the Jettin bushings will make a difference to bottoming out. They do not make the rear suspension any more firm while riding in my experience with them since the spring. They decrease the lateral play in the rear suspension but do not make the ride any firmer.
@stoker avatar
@stoker avatar
Thanks, and for once I'm not being sarcy, the skateboard stuff was really interesting 8)
@rgconner avatar
GTS250
@rgconner avatar
GTS250
Re: New Shocks
I won't disagree, it is my experience. It may be just the lack of hinging making it "feel" more firm and less likely to bottom out. Definitely more responsive and more "connected" to the ground. Handles much better at all times.
@elvispa avatar
GTS 300
@elvispa avatar
GTS 300
If I could turn back to the "shocks" for a moment.
I have begun to look around for possible replacement shocks for my GTS 300. I don't bottom out much, and in day-to-day riding along it is pretty good. However, I suspect that as with many scooters and motorcycles (maybe not top-line sportbikes), the aftermarket shocks might be a bit better than the basic shocks that come standard. I have found before, and would again be looking for more tune-ability, perhaps more travel, or at least a progressive action that give more energy absorbing capacity. It is pretty surprising how much a modest shock upgrade can do for your riding.
I have heard that the Bi-Tubo shocks are quite stiff, so that might not be the way to go. Are there levels of performance in the Bi-Tubo or is it just one way? I have also seen another shock on one of the Vespa-related sites in the "performance" area, which I vaguely remember to be made by YSS or something like that. Does anyone have any info on that one?
[ Time: 0.0236s ][ Queries: 3 (0.0098s) ][ live ][ 343 ][ ThingOne ]
