@retro_s avatar
vespa s 125
@retro_s avatar
vespa s 125
ok i bought a new choke cable (inner and outer) how does it attaches to the knob and the choke hook? you just turn the cable? or there are some other fittings. pics greatly appriciated
@jeremy_w avatar
79 P200e, 81 100 Sport
@jeremy_w avatar
If it's anything like my P cable there is a loop at one end of the cable, this is for the carb. The other end had kind of a hook.
You need to remove the gas tank and jam the crimped metal end of the cable in the tube for the choke cable inside the tank area. The hook end should poke out of the choke tube on the outside of the bike.
The choke knob should have a hole in it for the hook. Hook this up then feed it back through until the choke knob is seated correctly.
Sorry, I don't have pics of this here.
@mdchanic avatar
GS 160 /4
@mdchanic avatar
GS 160 /4
ScooterHelp has a good set of instructions for this.
Basically, the knob end has a double-90 degree bend, and I'm not sure what the T5 has on the carb end.
The double bend passes through the hole in the knob shaft. There's only one correct direction, so be careful.
The other end connects to the choke part of the carb.
The hairpin spring clicks against the choke knob in a way that is as simple as it is indescribable, and provides friction to keep the knob where you put it.
You disconnect the carb end and pull the knob all the way out of the tube, then disconnect the wire, pull it back out, push in the new wire, slip it through the knob shaft the way the old one was, push the inner back through the outer, and reconnect to the carb. Check and photograph the position of the hairpin spring first, because you'll never remember it afterwards.
But look at scooterhelp - it describes it well.
- Eric
@retro_s avatar
vespa s 125
@retro_s avatar
vespa s 125
tanks guys, ill fix it tomorrow.
[ Time: 0.0123s ][ Queries: 3 (0.0054s) ][ live ][ 343 ][ ThingOne ]
