got that fixed, and moved on to other things. for awhile now, i've been trying to figure out why the mf-er will shift fine 1st through third but hate going to 4th gear.
finally pemkt and my friend dave figured it out. when the tree branch fell on it. it slightly bent the metal tube of the handlebar assembly down.
as you rotate the shifter, the 'blocky' part of the handlebar rubs against the metal underbody of the headset. it's a small gap, but by the time you rotate it all the way to fourth, it's metal rubbing against metal, and that's what's making it a bitch to shift in to fourth gear.
here's a pic of what i'm talkin' about willis:
if i could bend the tube/assembly up an eigth of an inch or so, all would be fixed.
i was thinking about hanging the scooter upside down in bad weather and hoping a big ass branch would fall off and hit it, thus replicating the original disaster, but that seems like a lot of work.
any ideas on how to bend this back without dropping the whole front?
