@mauirain avatar
GTS250ie
@mauirain avatar
GTS250ie
Hi, I'm changing my rear tire and everything is off except the swing arm (and wheel). I wiggle and pry but can't seem to budge the swing arm bering
from the axel. I took off the two swing arm bolts.
Any advice would be much appreciated.
Thanks, Chris
@oneeyedjack avatar
GTS 250ie
@oneeyedjack avatar
GTS 250ie
I guess I don't know why you are removing the swing arm?
If your intent is to change the rear tire, check this.
https://modernvespa.com/forum/topic10536
Search is your friend
@mauirain avatar
GTS250ie
@mauirain avatar
GTS250ie
Thanks for the good link. I am doing a tire change.
That swing arm is on the axel really tight. Maybe I'll let some WD-40 work it's way in.???
Aloha MAUI. I would WD-40 anything you need to get off that's tight. Our beautiful salt spray does wonders for nuts,bolts and everything else Works better than locktite (sp) Good luck.
@woodenhead avatar
GT60
@woodenhead avatar
GT60
Try a large puller as a last resort, but first:
Swing arm removal on GT200
A flat bar can help, too.
Clean the shaft up after it's apart and give a wipe with copper grease (or something like that) before reassembly.
good luck
@mauirain avatar
GTS250ie
@mauirain avatar
GTS250ie
stuck axel to swing arm
Hey Judy! Alas we never met as the Inter-island Super Ferry is no more. Please give my best to John. I think I need some sort of gear puller for my axel problem. I just put 10,000 miles on my scooter last year! 10,000% fun miles, haven't dropped her once. I'm getting a German Shepherd Puppy Dog in a few months and plan on him riding in a special seat behind me. I'll post some pics when this happens. Cheers Judy! Stay safe!
Aloha,
Chris
@paul_g avatar
GTS 250ie
@paul_g avatar
GTS 250ie
A matter of semantics here. Vespa calls the trapeze contraption the motor/transmission is hung onto the "Swinging Arm". They call the part in question the "Suspension Arm".
This is, of course what anybody with any knowledge of motorbikes would call a "Swing Arm" as that is its name. The "Swinging Arm" of Piaggio nomenclature should probably be called the "Rotating Engine Hanging Doohickey".
P.
@oneeyedjack avatar
GTS 250ie
@oneeyedjack avatar
GTS 250ie
P.
Thanks Paul G. Didn't know what that "doohickey" was called.
@drewteague avatar
@drewteague avatar
good luck
+1
As with any seized components, tap both components, in this case the inner bearing race and the driveshaft, with a mallet, lightly at first. You can focus the taps with a punch or old screwdriver. Then apply a penetrating oil like WD-40 or PB blaster. If you have to pry against the wheel, wrap the tool in a rag or something else to avoid marring the wheel.
[ Time: 0.0122s ][ Queries: 6 (0.0027s) ][ live ][ 343 ][ ThingOne ]
