I just came inside from wrenching on my SS180...prettying it up, getting it ready for the rally tomorrow.
I loctited the 6 bolts that hold the flywheel fan to the center boss thing. Remember that GS / SS have a 2 piece flywheel - the outer fan part bolts to the center cam section ( every other bike these two pieces are riveted or welded together ). The GS uses 3 bolts to hold them together, the SS180 uses 6. The SS180 has a big design flaw with this because there's seriously NO clearance between the cowl louvers and the spinning 6 bolts. If one of the bolts comes slightly loose, it thrashes your louvers. It's why so few SS180's you see have intact, unbent louvers.
The 6 dome-headed bolts i used previously were on using lock washers, which spaced them out about 2-3mm more from the surface of the flywheel, and put them dangerously close to the cowl louvers... so i thought that removing the washers and loctiting them down was a good idea... to lower the profile.
Well, fuck.
I put it all together, kicked over my scooter, and nothing. Checked the spark...no spark. WTF? this bike ran fine the other day. Tried a different HT coil. Nothing.
Pulled the flywheel and i see this mess of copper shavings.
One of the screws i used to bolt down the flywheel was a few mm longer than the rest. Never matter before because it never scraped on the coils. But because i removed the lock washers, suddenly it was 2mm deeper...
and it gouged the everliving shit out of my ignition feeder coil on the stator, ruining it.
I thought "well, that's it, then...i'm riding the Jet200". That sucks because the SS180 has been running like an absolute champ and i was excited to take it on a 60 mile long ride.
But, these coils are easily swappable...so i called my buddy who i just changed out his Sprint from points to electronic ignition. "hey - can i have your old stator" "sure". He takes a picture of it for me, and the ignition feeder coil is the same.
I breathed a sigh of relief...i didn't know if the one i had was GS / SS specific, but it looks identical.
So, tomorrow morning we'll see if i can't get it in shape quickly. Good thing i took the day off.
-Eric
