2020 GTS Notte
2020 GTS Notte
I'm not sure if I am phrasing this properly, but my 2007 GT200 has a very shaky start-off when I throttle up from a stop. It starts up fine, so there are no issues there. I also notice some sputtering when I come to a stop. The rest of the ride is great and I have NEVER had it stall (I know I'm jinxing myself now!).
Does anyone know if this is normal? I have 1,600 miles, so it is relatively young. It has had its 600 mile break in service in 2008, and another oil change and check-up service by the dealer at 1,550 miles, so it's not like I'm neglectful.
I'm just extremely ignorant and wish that I knew more.
Any thoughts or suggestions are appreciated.
sounds like the normal on again off again judder of the belt/clutch. A lot has been written on that on here and it happens to mine once in a while, weather dependent I reckon. Some blow out the dust in their clutches and swear by the fix, some have sprayed brake clean a CRC product in there. I have done nothing when it happens I ride it a little harder off the line and it seems to go away then a few months later it will return. I have another GT, had an ET4 and an X9 and they did the same thing occasionally, assuming we are talking about the same judder on slow acceleration from a stand still or very slow speeds ussually happens in crawling traffic.
The sputtering if exhaust could be your exhaust donnut unlikely with your low mileage if it is like a rattle it could be the normal roller settling in cage noise.
2020 GTS Notte
2020 GTS Notte
That's interesting, and might explain why the rest of my ride is fine. It certainly isn't a consistent phenomenon. I would say it happens every 3rd of 4th outing. When I start off at say 5 miles an hour, it is fine. ITis when I pull on the throttle for a fast start-off from a stop (real acceleration) that I feel the shuddering, then it works itself out. Thanks for the insights.
[ Time: 0.0119s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
