I've got it ordered and should get it this week.
I'm going to get the clutch pre-setup with the correct type of pillow and clutch springs as per the document (201203 Nextd. clutch RRef.doc) posted by Dr Pulley (paul@unionmaterial.com) in this post: Clutch with the J. Costa?
UPDATE: Do not use the configuration recommended by Union Material for a MP3250ie. It resulted in poor performance, and a potential spring shear in the clutch. Read later post for more info, including symptoms.
I got my clutch by first checking this document, which details what clutch for what scooter:
http://www.unionmaterial.com/HiTClutchType.pdf
The key to selecting the correct HiT clutch kit is the Clutch Bell diameter, specified in the document for you to match with your OEM Clutch Bell.
I am looking for as close to OEM as possible, so I can eliminate the "Strangled Sealion" and get a little bit more peppy performance. But not so much that I loose the ability to do inner-city riding in peak hour.
So when I have got the clutch installed, I'll post my findings.
I believe larry8 has the HiT Clutch installed as well, so it would be interesting to hear what he thinks as well.
⚠️ Last edited by jaredmorgs on UTC; edited 2 times
