Changed the belt and JCosta'd the variator last night (thanks to you all). So I figured while I'm workin in the area I'll clean the air filter. I undid the first few screws on the lower right hand side and oil poured out.
Down the driveway it goes. I'm scambling to clean it up because I was't prepared for that. A lot of oil came out and obviously that's not right. So why could this have happened and what is the most likely reason.
Thanks,Mike
