@sjberg avatar
2007 Sky Blue LX150, 2007 Daring Plum LX 150
@sjberg avatar
GLove box is off and I got the lower side panels off and the scrwes out of the rear foot rests. What else is there holding the floorboard in place?
Thanks,
Steve
@copper_dolphin avatar
LX150 Darling Plum; GTS 250 Dragon Red; Honda Big Ruckus Demented Bastard
There are several posts that show there are screws under one of the rubber strips, I think it is the outside one on each side. I forget how many screws are under there but should be no more than 3. Just pull up on the outside strip till you can find the tab spot then just pull up at the tab spot till it pops out. Work your way down to both ends, but you will not have to remove the rubber strip all the way. You will know when your done.
if you look at this post of mine (8th picture), it shows what I am talking about on my GTS 250, very much the same kind of thing on the LX150.
https://modernvespa.com/forum/topic47506?highlight=
@sjberg avatar
@sjberg avatar
Bingo! Under the middle strip on each side.
Thanks, I didn't want to just start tearing things apart.
Steve
[ Time: 0.0224s ][ Queries: 3 (0.0047s) ][ live ][ 343 ][ ThingOne ]
