veloce75 wrote:
[color=indigo]but I more like point ignition... cheaper and easy to install especially when we're on the road no need solder just screw it.
So... in my first few years of doing vintage scooters, the first thing i would always do would be put in either a P-series engine, or do an electronic ignition conversion.... because i thought points to be inherently bad, and fault-prone.
The combination of two events have led me to change my mind.
1) When i got my first lambretta, i began ordering parts from Casa Lambretta. At the time, Alex... the owner... was still answering the phone and taking part orders. I would get into these long conversations with him where he turned my ideas about wrenching on scooters upside down. I had always considered the things that were original on these bikes as junky, and needing modernized. Wanting to put disc / hydraulic brakes on everything...electronic /12v... bitubo suspension... top end kits ..etc.
Casa doesn't sell any of that stuff. They sell no performance parts. Alex really had the mentality that these things were perfect as they were... and that ultimately people go swapping out things to treat a problem, rather than solving the problem correctly. For example - you've got misadjusted points, or your bike is improperly timed...or you have a faulty HT coil, or lighting coils, ... so you put in electronic ignition because it's easier than fixing the problem you have with your existing points / 6v system.
A drum brake is perfectly fine, if it's adjusted and maintained properly. 6v lights can be REALLY BRIGHT if you have good magnetism, proper wiring and grounds, etc.
The bike was better thought out than you THINK it was... and it could be that you just need to adjust your perspective. It takes a BETTER mechanic to keep something that was original going strong, rather than slapping a new part on whenever the old one goes bad.
2) The acquisition of my GS and SS ...and restoration ... because there ARE no performance parts for them... there's no electronic ignition kit, etc. You are FORCED to make the original stuff work ( and really, you should rock the stock stuff anyways, to keep the value strong ).
