2023 GTS 300SS, 2022 Honda Africa Twin
Posts: 71 Location: Thousand Oaks, California |
The vent hose comes out of the gas filler neck on the front and it turns 90 degrees to the right. I ran it between the right side of the frame downtube and the gas tank (about in the middle of the tank). Then, I cut off the excess. I did this about five months ago and it works fine.
Posts: 46316 Location: Pleasant Hill, CA |
jimc wrote: Straight down to the ground. You may need to extend it. |
Question for jimc about the overflow tube.
When I removed the evap system, I cut the tube off just below the hole in the under seat compartment where it entered the rollover valve. I did not cut it short to hang to the ground. I suspect that, in an overflow situation, some fuel might remain in the tube where it begins to ascend upward. I have noticed some fuel smell on long and bouncy trips, but the performance does not seem to be affected at all. Does it matter? What, in your opinion, will be the consequences of leaving it this way, if any? Thanks, Durdle |
Posts: 1932 Location: Ohio |
XLR8 wrote: jimc wrote: Straight down to the ground. You may need to extend it. Bob |
durdle wrote: Question for jimc about the overflow tube. When I removed the evap system, I cut the tube off just below the hole in the under seat compartment where it entered the rollover valve. I did not cut it short to hang to the ground. I suspect that, in an overflow situation, some fuel might remain in the tube where it begins to ascend upward. I have noticed some fuel smell on long and bouncy trips, but the performance does not seem to be affected at all. Does it matter? What, in your opinion, will be the consequences of leaving it this way, if any? Thanks, Durdle |
Jimc
Thanks for the non-answer. I ask a specific question on what you thought would be the consequences of doing what I did. Guess you have no opinion. That's OK too. Durdle |
No, really - the overflow tube must go down, down, down, with no 'up' in it. Or am I completely missing what you are asking?
I am simply speculating that if the hose goes down, then horizontal, then up slightly, the only thing that can happen is that a small amount of fuel could stay in the hose at the lowest point. I assume it would evaporate and cause no harm. I just asked for an opinion about that. Is there any harm in that?
I have no performance problems, but sometimes smell gas, which you probably do with the hose going down, especially if it is filled to full. |
durdle wrote: I am simply speculating that if the hose goes down, then horizontal, then up slightly, the only thing that can happen is that a small amount of fuel could stay in the hose at the lowest point. I assume it would evaporate and cause no harm. I just asked for an opinion about that. Is there any harm in that? I wouldn't - I'd re-route as per the rest of the world. Quote: I have no performance problems, but sometimes smell gas, which you probably do with the hose going down, especially if it is filled to full. Your tank needs a vent, give it one. |
Yes...............It will allow over-flowed fuel to stay in the line and prevent the tank from venting. This can cause the same symptoms as having a clogged canister.
As Jim said................Point it DOWN. |
Anyone have pictures of where the end of the tube goes, and how to secure it to the bike? Thanks.
No pictures (sold my BV500) but the overflow tube comes off of the front of the scooter behind the plastic cover just behind the front wheel. The nipple points towards the right side so I just ran mine towards the right floor board and tied it with a nylon zip tie between the floor board and the frame. (pointed towards the ground)
