Vespa GT 200 starter turning but engine back fire once now unable to start
The starter is turning ok and engine oil is ok
It was running fine 1 day ago?
Did I flood the engine with gas?
Now it's had time to evaporate a bit, try again and re-post with findings?
vespa can not start
Do I remove the evaporator hose temporarily while starting the engine?
or reconnect ?
vespa can not start
evaporate already but did not start
The starter spins without a lot of sound
Tight (frozen, frightened, stuck) bendix gear methinks. Take the transmission cover off and examine. Eyes on the ground are far better than forum voices.
@greasy125 avatar
@greasy125 avatar
i'd start with the basics:
is the starter bendix engaging the ring gear starting pulley
is the ring gear starting pully in good condition
is the battery fully charged
is the starter relay in good working order.
from there i'd delve deeper:
plug, air filter, carb, CDI, stripped crank...
need... more... info...
current mileage, date and mileage of previous service, etx
otherwise it's all shots in the dark.
best,
-greasy
vespa can not start
THANKS
I will check all of the bendix because the battery is strong
My bet is the outer pulley splines have rounded off. But we'll have to wait until it's been opened up to find out.
@harvey avatar
@harvey avatar
Hi Steve:
Do you have the workshop manuals?
Jimc has been kind enough to provide them here:
http://manuals.wotmeworry.org.uk/Vespa/GT200/
Good luck with it!
Harvey
[ Time: 0.0170s ][ Queries: 3 (0.0026s) ][ live ][ 343 ][ ThingOne ]
