So, we know we're going to have to weld in a piece to make up the difference when we cut some of the cancer out of Sunny. I'll post a picture or two of exactly what we're dealing with here at the bottom. My question is, dad seems to think there should be "patch pieces" that we can get that are shaped correctly to replace something like this that we can just cut to fit our hole and weld in. I wasn't so sure because Vespa have the famous unibody frames. Has anyone heard of anything like this? If they don't exist, do you think it would be a better idea to try and find an old frame we can hack up (expensive methinks!) or just grab a piece of steel and make due? The piece we're trying to replace is probably going to be about 2 inches wide, top to bottom, and maybe two feet long? I'm totally guessing on that measurement. Any suggestions?
Posts: 6980 Location: Detroit, Michigan |
What's probably happened there is that the battery boiled over, and acid poured down into that and rotted it out with sulferic acid. There's a lot of bikes of that era with the same rot.
Can't you just weld in a section of sheet metal in it's place? I mean, this isn't going to be a show bike...and it's going to be covered up by the glovebox anyways... just a thought. |
Rover Eric wrote: What's probably happened there is that the battery boiled over, and acid poured down into that and rotted it out with sulferic acid. There's a lot of bikes of that era with the same rot. Can't you just weld in a section of sheet metal in it's place? I mean, this isn't going to be a show bike...and it's going to be covered up by the glovebox anyways... just a thought. It was definitely battery acid though. The floor of the cowl where that thing used to sit is completely gone (I think I posted a picture of that here before) and everything's all bubbly around there. Once we get to that point, I'm definitely going to do the 12v conversion so something like this never happens again. |
i can assure you that short of gutting another frame.... which would have to be one that's somewhat similar ( sprint / super / GT, basically )... you're not going to find a "patch kit" as you describe.
There wouldn't even be the floorboard replacement kits you see, if the vietnamese hadn't started repopping those because of the jungle climate and leaving their bikes outside 24/7 hadn't rotted out all their frames! Those weren't ever an italian-produced item, AFAIK. |
Ouch. Didn't know floorboards weren't a standard replacement part. Oh well, as long as they're metal and the welding's done right, it shouldn't be a big issue. The only thing that I'm not excited about with replacing that strip behind the cowl is that my VIN is gone. I've still got it on the plate up front, but those pop off so easily. Maybe I can use dad's old engraver and put it on there just in case. It might not look good, but it'll work.
hi dully, i hav'nt talked to you in a while
i'm glad you got yourself a scoot vespa yellow is one of my favs, classic metal work is fun remember that sheet metal of this gauge responds differently to heat shrinkage or ribboning you will need a good 4" grinder too have fun |
I'd call around to some shops... and post up some wanted ads on various boards. There must be some seriously knackered frames out there, whether from accidents or other failures, from which you could cut out that section of panel. That way at least you'd have the proper stampings and brackets in place on that side.
Starting to feel a little sympathy for the bodgers now aren't we! |
Posts: 4134 Location: St. Petersburg Florida |
Dullivan wrote: Ouch. Didn't know floorboards weren't a standard replacement part. Oh well, as long as they're metal and the welding's done right, it shouldn't be a big issue. The only thing that I'm not excited about with replacing that strip behind the cowl is that my VIN is gone. I've still got it on the plate up front, but those pop off so easily. Maybe I can use dad's old engraver and put it on there just in case. It might not look good, but it'll work.
Neutral
VEZPA wrote: Dullivan wrote: Ouch. Didn't know floorboards weren't a standard replacement part. Oh well, as long as they're metal and the welding's done right, it shouldn't be a big issue. The only thing that I'm not excited about with replacing that strip behind the cowl is that my VIN is gone. I've still got it on the plate up front, but those pop off so easily. Maybe I can use dad's old engraver and put it on there just in case. It might not look good, but it'll work. |
Moderibbit
Posts: 8891 Location: Atlanta, GA |
Which is why you can't trust a vietbodge VIN.
Dully, I think you can do it. And I think you can make the sheet-metal look good too if you go that route... as Eric pointed out, it's going to be hidden by the glovebox anyway. |
My uncle has been a master welder for years so I'm not worried about the work, just the materials. I was just trying to figure out what would be easier, because it seemed like just picking up a kit would be the best idea, but if they don't exist, we'll just use sheet metal. I definitely agree that it's behind the cowl, so looks don't matter, just the quality of the job.
Dullivan wrote: My uncle has been a master welder for years so I'm not worried about the work, just the materials. I was just trying to figure out what would be easier, because it seemed like just picking up a kit would be the best idea, but if they don't exist, we'll just use sheet metal. I definitely agree that it's behind the cowl, so looks don't matter, just the quality of the job. And no you can't have my floor. I'm using it. |
1967 Gran Turismo 1963 Lambretta S3 TV175 1971 Rally 180
Posts: 1406 Location: Minneapolis |
danyouhandleit wrote: Dully, you gotta post some more pix as you go. Now, any suggestions on how to get the clutch handlebar to turn freely? We're working on the cylinder by letting it soak in some sort of spray my dad has, but we have no idea how to treat the handlebar. The only way you can turn it is via rubber mallet, which isn't very convenient while riding. |
SS-180 x 1 (dead) SS-180 x1 (3'rd times the charm)SS-90 x 1 GS-160 MK1 x 1 P-200e x1 TV 175 S2
Posts: 237 Location: San Diego, California |
Okay where do I start? First of all the best method to get rid of all the rust and see what you are really working with is chemically dip the frame and make sure that it is still a viable candidate for restoration. You don't want the frame to buckle at speed causing you to become one with roadway if you know what I mean. The Vespa frame/fuselage requires structural rigidity to be safe, any rust compromising certain sections is asking for disaster. I lived in Hawaii and have dealt with rust far worse than any Florida rust and know when things are beyond repair and that frame is pushing the safety envelope. A new frame from a scooter shop might be the best fix here.
Secondly the frozen piston has become one with the cylinder and will probably need to be pressed out with a hydraulic press, but first that will require you having to remove the cylinder from the case. You may need to cut the crank and more to get that thing off. I would be surprised if any secret sauce mix will do anything to un-stick that piston. Have you removed the flywheel yet ? Third, it seems that you still have the clip that hold the shifting tube still connected. Remove the clip and work the tube off the headset with you mallet if need be. |
Posts: 1847 Location: San Francisco, CA |
to get the shifter free:
1. turn it (via mallet? be careful!) to where you can pull the pin out (under the handlebars). 2. pull out the part that holds the shifter cables (inside the headset). it will slide out from inside the tube. 3. spray lots of wd-40 on the shifter tube... just keep working it until it comes out. it will get a little easier when the part inside the headset is free... looks like there's lots of rust/grit on the shifter tube... if you can get it free enough to spin, you might want to clean it as much as possible with steel wool (or something?) the clearance on the handlebar is tight, and anything adding to the diameter is going to make it more difficult... then again... you could try to find another headset. looks like there's a big chunk missing in the casting where the speedo goes! have you thought about getting another frame? that one is so rotted away , very close to the engine mount! i wonder of this guy still has his Bajaj frame. it's basically the same. Think it's a Chetak (same as Sprint). It's possible that Sprint and Super frames are the same (just different cowls/fender?) http://scoot.net/classifieds/forsale.html?id=17647
Thanks for the tips. I didn't see that little clip in there until I was taking pictures afterwards. The accelerator side came free so easily, we weren't even looking for anything like that, just taking off anything we could get unscrewed (and some things we couldn't...rusty bolts + Dremel tool = good times) and were towards the end of the day when we were doing that part, so I guess we weren't paying enough attention.
ktmdriver wrote: Secondly the frozen piston has become one with the cylinder and will probably need to be pressed out with a hydraulic press, but first that will require you having to remove the cylinder from the case. You may need to cut the crank and more to get that thing off. I would be surprised if any secret sauce mix will do anything to un-stick that piston. Have you removed the flywheel yet ? |
Typically, a seized top end can be freed with just a hydraulic press. ( even a cheap harbor freight one )
It is a bit of a bitch to get the cylinder and crankshaft free of the engine, though... you gotta remove cylinder studs and such. If you try to hammer out the cylinder, you might cave in the piston and shatter it. I've seen that done a bunch, too. Shouldn't be any need to CUT anything... and the cylinder should be able to be bored out to an oversize, and you can run the corresponding new piston and rings to match that oversize. |
Posts: 5109 Location: west aus |
