@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
Maybe a misleading header, but I bought a product that will make my riding safer, but first, an intro.
I must admit that on a bitchy hot day when I am just going to zip into town for the mail or something, I sometimes don't wear my helmet. My biggest objection to the helmet is the D-rings and the strap. I hate fooling with them.
I had read on this forum about a metal buckle assembly that would convert the strap to use a quick release buckle. The price was fairly reasonable.
Recently, I found another product on line that was even cheaper and was made of high strtength plastic, but had a DOT approval. The item is the Powermadd Speed Clip which has a push button release. I bought mine (2) on-line for $6.97 ea.
The reason I feel that it may be a safety issue is because now I will wear my helmet ATT, since it is simple and quick to get the helmet secured.
I did saw the D-rings off, although it isn't necessary.
Here is the link to a good product:
http://www.powermadd.com/products/speedclip.html
If you don't like D-clips, why buy a helmet with them? My current Shoei is the first one for about ten years which has D clips. I don't mind, I just have to remember to do the helmet up before putting gloves on.
@nightwing avatar
Contributor
Contributor
@nightwing avatar
At the time I bought the two helmets, I thought the D-rings were industry standard. So, I will claim ignorance, but not stupidity. Razz emoticon
GTS 300ie
GTS 300ie
I have one of these clips on my old helmet. I didn't put it on the new one, because I felt it prevented me from tightening the helmet as much I need to. Whatever gets people wearing helmets and doesn't hurt others is fine by me.
@nightwing avatar
Contributor
Contributor
@nightwing avatar
You can adjust the strap as required and then it holds that adjustment, even after being opened.
@chetwynder avatar
Baart-less
@chetwynder avatar
Baart-less
I have something similar on my old Zox. Slightly different design but does the same job. It works as advertised. Believe it or not D ring systems are not all the same. I put my clip mechanism on because the Zox D rings were driving me nuts. The D rings on my new Icon are easy and convenient to use. Don't ask me for an explanation 'cause I don't have one...
Dave
GTS 300ie
GTS 300ie
I know. I have a small head, so I have to choke up really hard on the strap. Even using the D ring, I choke up on it really hard. The plastic clip just took up too much length on the strap and wouldn't allow me to tighten the strap enough for my comfort.
[ Time: 0.0153s ][ Queries: 3 (0.0055s) ][ live ][ 339 ][ ThingOne ]
