I was all excited to get home last night and use the delivered gasket and seal kit to finish up the ET3 ... hoping i might even be able to button up the engine to the extent that i could mount it back in the bike.
No such luck. I spent 3 hours trying to get the fucking cases to close.
It's not that they WOULDN'T close ..it's that whenever i put some torque on the bolts around the crank area, the crank would basically lock up and stop spinning. Loosen the bolts so there was a mm or two between the cases, and it would spin free again.
Clearly the crank isn't seated right, and someone else has the club tool to pull the crank into place... and i got really pissed off and frustrated and called it a night.
