My 65 VBB was giving me taillight troubles, I believe I have that straightened out, I have a question about a square box that is mounted behind the coil. Black wire is to ground, yellow wire is connected to a terminal in the little junction on the engine. It says "Timpanium". I doesn't show up in my wiring diagram
http://www.scooterhelp.com/electrics/wiring/VBB1_VGLA1_VGLB1.pdf
in this photo you can just see the top of it between the brown junction box and the coil.
Do I need it ? does this help regulate the current ? Where should it be connected ? Thanks for the help, sorry if these are stupid questions.
@rover_eric avatar
@rover_eric avatar
it's a small 6v regulator that someone has bolted on there.
You SHOULDN'T need it if you have all the proper bulbs in your bike.
Remember that i recently wired one onto my SS180, thinking there was something wrong with it ...but later realizing i had the wrong / blown bulbs in it. Once i fixed those and put in the correct ones, i was fine.
and it looks like your taillight circuit that's getting regulated... which includes both the tail light and your pilot bulb. If you're not running a pilot bulb, or you don't have one in place, that explains why you keep blowing the taillight bulb.
Boy Eric you nailed it, I thought my tail light wiring was bad, but both my tail light and pilot blew after adding the rubber bits to the coil and junction box. so maybe I do need it ?
BTW I did just order new correct bulbs from scooterworks
@rover_eric avatar
@rover_eric avatar
Anytime you order bulbs, order like 4 of each. Trust me.
already there, I ordered 6, plus 2 headlight bulbs
@rover_eric avatar
@rover_eric avatar
Hey Rob ...did you know the Not Summit Point camping rally is coming up in in October... and it's actually in Gettysburg, PA ?
http://scoot.net/calendar/NSP18:JunkyardDogs
Thats Awesome. I'l be there on Saturday !
[ Time: 0.0104s ][ Queries: 3 (0.0042s) ][ live ][ 343 ][ ThingOne ]
