I know you all like to look at dirty pictures so here's one of my piston.
I was riding up to Long Beach last weekend for the LBCSC monthly ride. Took the 5 freeway for about 20 miles through Camp Pendleton (it's either freeway or take a 2 hour diversion to get around the camp), going steady 3/4 to full throttle - varying it. No problems. Pulled off at San Clemente and stopped to make a few phone calls. No problem. Carried on riding on PCH, stop and go traffic getting up to 45-50 ish. No problem.
Decide I'm getting thirsty after about 15 miles so in Newport Beach I stop and have a drink. Go to start up again ang the engine turns over and I here a metalic pink-pink-clink-clink sound and it dies. Problem.
This is what I found when I opened up the cases yesterday. The area around the wrist pin that the circlip clips into had disintegrated and the clutch side circlip had done the same thing.
Broken piston
Broken piston
@oopsclunkthud avatar
1:3
WOW!
I can't even begin to think how that could happen.
Mark that sucks.
How do you get a hole in your piston?
Looks like you are ready to kit that thing
I will be at Hensley's Flying Elephant Bar tonight. If ya need a drink let me know.
J
VLBJS1 wrote:
Mark that sucks.
J
I'll be putting my old jug and piston back on on Monday, so at least it'll be running. Thinking about a kit, just need to decide which one.
I'm going to see Deadbolt down in SD tonight, but have fun at Hensley's
@hp avatar
@hp avatar
Wow that sucks... good luck getting back on the road.
Would be instructive to know what piston this was... Looks like a wire circlip so it wasn't original... was this a pattern stock kit?
Yeah, it was a stock replacement kit that I got from MotorSport back in May. I had about 2000 miles on it.
@greasy125 avatar
@greasy125 avatar
oofah... that sucks the big one.
i'm with HP, this looks to be some type of mfg'ing failure. while i've seen my fair share of busted parts, this intrigues me.
i looks as if that's been going on for a lonnnng time and it finally just shit the bed.
interested to know what the orgins of that top end were.
best,
-greasy
@wibbo avatar
PX200E
@wibbo avatar
PX200E
Engrave it "offering to the god of speed" and place it on your bookshelf.
Never seen damage like that before
nothing at all
nothing at all
i'm glad it did'nt happen on the pendelton/onofre stretch
although you would've been closer to home
@koenig_blues avatar
thats suck but glad u have a replacement piston, still how can ur piston gave up like that unless u drive it like hell (speechless) Wha? emoticon
@sifty avatar
Maicoletta 250, Maicoletta 277, GTS 250
@sifty avatar
I saw this on a Vespa in Italy...
I think you earned one..
@smallstate avatar
@smallstate avatar
agreed. that is a massive failure. you should keep that forever.
@sifty avatar
@sifty avatar
my last offering to the speed gods went like this:
Subaru Legacy GTB cambelt skips a tooth at redline in 2nd gear
@edmn1mpr avatar
1966 Vespa 180SS
@edmn1mpr avatar
1966 Vespa 180SS
broken piston
Looks like preignition to me , poor gas and bad ign timing wrong spark plug heat range <<< no matter what it was it's broke
EDM
@killo avatar
I have a few scooters....
@killo avatar
That really sucks. What does the bore look like?
Re: broken piston
EDM
Factory timing marks lined up and checked with a timing gun and degree wheel.
B8ES plug and always 91 gas
But if you can explain how it would do this to the area around the wrist pin only I'd happily accept that and learn from it.
Bore looks good everywhere apart from where bits of the circlip (?) got caught between the the barrel and piston - there's a big gouge that I need to look at more - it's pretty deep and may not be worth re-boring.
nothing at all
nothing at all
i will say it was a bad cast on that piston Nerd emoticon
either air or dirt got in the pour and you gave it a bad day
@killo avatar
@killo avatar
I've heard of the wrist pin retaining clips popping out either because of improper installation or manufacturing defects. Once out, they rattle around as your piston slams up and down. It looks more like this scenario to me.
[ Time: 0.0195s ][ Queries: 4 (0.0090s) ][ live ][ 343 ][ ThingOne ]
