I've discovered that I have an exhaust leak, which from feeling around the pipe seems likely to be where the much maligned gasket No. 826388 is.
After several experiences with looong repair times at the two shops near me that will work on my GT200, I've been doing some repairs on my own. I'm hoping to do this on my own, too, but would appreciate some advice.
1. My whole exhaust system seems pretty rusted. I have just over 4,400 miles on my baby, and she's just 2½ years old, but I have no place to get her out of the elements, so she does tend to get wet often. Should I just buy and replace the whole exhaust system with either the OEM or an aftermarket kind? Any recommendations on a specific exhaust system?
2. I see on here that the some have had problems with the brass bushing used as a replacement for the original exhaust gasket. Should I stick with the Piaggio gasket?
And 3. I did drive for several days after the noise started, before I figured out where the leak was and read all these frightening stories about losing your brakes. My rear brake line has a little melty spot on it near where the leak is. My brakes are fine, but I want to replace the brake line as well. Super complicated?
