whatever i can crash
It's not like the cable snapped, the mofo won't even turn at all. I tried knocking a few times with a mallet to see if I could push it back, but to no avail. What could be the problem.
nothing at all
nothing at all
pull the headset off and take a pic and look around in there
will do
@jeremy_w avatar
79 P200e, 81 100 Sport
@jeremy_w avatar
If it won't turn you most likely bent the throttle tube. You can buy a new one from scooterworks clicky linky
Hopefully you only bent the throttle tube and not something in the lower headset...
@mdchanic avatar
GS 160 /4
@mdchanic avatar
GS 160 /4
The bike is totalled.
You need to sell it to me for $25.
I will be down during Mardi Gras to pick it up.
- Eric
@chad avatar
Olivia Newton-John
p200, vbb, gt200, px150, vnb
Olivia Newton-John
@chad avatar
previous owner did the same thing to my p, only on the gear side. turned out it was what jeremy said, bent sleeve. motorsport has them new for $50 or so.
Here's some pics.
thanks!
nothing at all
nothing at all
those pics are ginormous
nobody is going to help you until downsize those things
i like a 800x600 range
PX 150 Serie America #122
How difficult is it to replace the throttle tube? Mine snapped at the grip area. It still works fine, but the grip is now about an inch or so away from the headset.
@vezpa avatar
@vezpa avatar
PLEASE DOWNSIZE THE PICTURES BEFORE POSTING TO AT LEAST 30% OF THEIR ORIGINAL SIZE !
@eldorado avatar
1980 Vespa P200E, 1981 Serveta Jet 200, 1982 BMW R100, 2003 BMW F650GS
@eldorado avatar
I would think if the tube broke you'd be able to push the grip at least into the headset...are you sure the grip is on the tube all the way?
Tube is easy to replace: open headset, take off spring clip holding the pulley on, take off pulley and spring washers, removed front brake cable from throttle tube (can just disengage at headset end if you have enough slack in the cable), disengage the tube spring, pull it out, reassemble in reverse order.
[ Time: 0.0115s ][ Queries: 3 (0.0057s) ][ live ][ 343 ][ ThingOne ]
