I came, I saw, I spewed...high test gasoline that is. I stopped of at the local stop and rob for some petrol, not more than fifteen minutes ago. Thought it would be a good time to try out my new McCuff. I took it out of it's handy little carrying case, gently slid it over the end of the filler nozzle (all of this as per instructions) and firmly held it on the fuel tank opening. I squeezed the handle (not full flow, mind you) and began filling. The familiar click of the pump shutting off never came. Instead, a big gush of 91 Octane blew out from under the McCuff and damn near filled my cat carrier. Well, maybe not that bad, but it ruined my favorite Ping ball cap. I immediately took the McCuff and stuffed it back into it's pouch, then stuffed that into the trash can next to the gas pump. I've been McScrewed out of twenty-three bucks.
Positive
Posts: 3908 Location: Antelope, CA, USA |
I think we've heard this story before? History repeats itself.
Sorry to hear you got spewed on. It's never a pleasant thing. |
you should have keep this report with dem's and dee's report , but good report. take out of trash and return it for a refund.
ALWAYS remove your pet carrier before filling with gas. Just set down in a conspicuous place so you don't leave it behind.....fill up.......put the pet carrier back in place and drive off.
Reprehensible Misinformant
Posts: 7576 Location: Winchester, California |
Re: The McCuff report
J. D. Hart wrote: I came, I saw, I spewed...high test gasoline that is. I stopped of at the local stop and rob for some petrol, not more than fifteen minutes ago. Thought it would be a good time to try out my new McCuff. I took it out of it's handy little carrying case, gently slid it over the end of the filler nozzle (all of this as per instructions) and firmly held it on the fuel tank opening. I squeezed the handle (not full flow, mind you) and began filling. The familiar click of the pump shutting off never came. Instead, a big gush of 91 Octane blew out from under the McCuff and damn near filled my cat carrier. Well, maybe not that bad, but it ruined my favorite Ping ball cap. I immediately took the McCuff and stuffed it back into it's pouch, then stuffed that into the trash can next to the gas pump. I've been McScrewed out of twenty-three bucks. It isn't even a good hockey-puck. |
GTS 250ie YELLOW N WHITE,Giallo Lime
Posts: 1374 Location: Beautiful Orange County CA |
J. D. Hart wrote: I came, I saw, I spewed...high test gasoline that is. I stopped of at the local stop and rob for some petrol, not more than fifteen minutes ago. Thought it would be a good time to try out my new McCuff. I took it out of it's handy little carrying case, gently slid it over the end of the filler nozzle (all of this as per instructions) and firmly held it on the fuel tank opening. I squeezed the handle (not full flow, mind you) and began filling. The familiar click of the pump shutting off never came. Instead, a big gush of 91 Octane blew out from under the McCuff and damn near filled my cat carrier. Well, maybe not that bad, but it ruined my favorite Ping ball cap. I immediately took the McCuff and stuffed it back into it's pouch, then stuffed that into the trash can next to the gas pump. I've been McScrewed out of twenty-three bucks. Here is the problem as I see it. It's 2 and a half inches high, I can see that the nozzle doesn't go insde the fuel tank far enough, so cut the McCuff down an inch, it's only purpose is to hold the rubber cover up so the spout will fill your tank. I was thinking of doing just this to mine today. I will report back on how I cut it back and how it's working, I refuzed to remove the cat carrier when filling my tank. |
YardSale wrote: Here is the problem as I see it. It's 2 and a half inches high, I can see that the nozzle doesn't go insde the fuel tank far enough, so cut the McCuff down an inch, it's only purpose is to hold the rubber cover up so the spout will fill your tank. I was thinking of doing just this to mine today. I will report back on how I cut it back and how it's working, I refuzed to remove the cat carrier when filling my tank.
Neutral
There once was a product McCuff
That many said was quite McDuff It didn't stop spills It didn't give thrills And most people said That's enough
Positive
