I get ask all the time from people who just bought a Stella or PX and thought it might be helpful if I would throw together a list of parts that are nice and cheap to have around when owing Stella/PX. In fact I always have at least a set or two for these parts just in case. Here goes....
manual
engine seals
engine gasket set
clutch plates/springs and NEW clutch nut. (soak corks in 30w overnight)
carb gastet kit make sure to ask for the float and needle
small end bearing and rings
shifting cross
fuel tap
All this stuff is pretty cheap (maybe around $150 to $200), but it's usually enough to give your scoot a basic engine rebuild.
Also, ALWAYS have a set of inner cables especially the shifter and clutch ones and pinch bolts. Well, these are the most common things I have seen that get replaced. Things like bearings, pistons, brake shoes tire etc I order when needed to save money.
Must have specialty Stella/PX tools are as follows...
clutch nut tool
clutch holding tool
flywheel puller
flywheel holder
forth hand tool
fuel tap wrench
All these tools might be around $100 or so at places like Scooter Works. Also, very helpful is a NEW C.D.I. and pickup box to test the old one with.
Not cheap but worth every penny is a motorcycle lift. Around $300.00 at Harbor Fright.
And of course always have a set of tubes around for good luck because when you don't have them that's when you need them the most.
@orange_s150 avatar
S 150, VNB 150, 101 Allstate, 01 ET2, 2005 PX
@orange_s150 avatar
thanks for the post!
@tomorrowmatters avatar
Red S150
Red S150
Excellent idea! Thanks for the list of parts
Damn! I forgot copper push rod for the clutch.
and flywheel and clutch wooddruff keys.
[ Time: 0.0086s ][ Queries: 3 (0.0025s) ][ live ][ 343 ][ ThingOne ]
