@suz avatar
2008 Vespa GTS 250ie
@suz avatar
Okay, I can't find anything in search on this one.
Since I always wear a helmet I was unable to hear the sound my baby(alias "Jet") makes on acceleration. Made a short trip to get fuel without my helmet today. During acceleration from about 25 mph up to at least 45 mph ( after that I don't know. To much wind noise) I hear a loud series of clicks from the front end. Since the Vespa is my first scooter experience can someone please tell me if what I'm hearing is the automatic transmission shifting itself. Geez, I hope so.
Sorry if this is a dumb question.
@davidh avatar
2009 Piaggio BV250 & 2013 BMW C650 GT
@davidh avatar
Re: Clicking sound during acceleration.
Probably not a dumb question but an incredibly dumb thing to do: "...Made a short trip to get fuel without my helmet today."
@suz avatar
@suz avatar
acceleration
Yes, I know. Goofy emoticon
@orange_s150 avatar
S 150, VNB 150, 101 Allstate, 01 ET2, 2005 PX
@orange_s150 avatar
my motor sounds like what you are saying but it is on my 150... could it be a cooling fan? my forced air fan makes a clicking type noise and so does my motor. Just are you sure it is from the front of the scoot?
Wear the helmet and you won't worry about the noise.
@suz avatar
@suz avatar
Good one JimC. You are right. I would never have heard it in the first place.
Yes, the clicking is coming from the front. Thanx
2009 Piaggio Fly 150
I don't suppose you can reproduce the noise by bouncing your scooter......violently.
It may merely be the usual 'whish' or 'click' heard while the holes in the disc(s) [rotor(s)] go past the currently sharp front edges of the brake pads.
@suz avatar
@suz avatar
Thanx Jim.
@vespa_hartford avatar
Sponsor
Sponsor
Radiator noise. Liquid passing through the radiators.
@biking_ben avatar
MP3 500
@biking_ben avatar
MP3 500
Did you ever find the problem?
I have the same problem on my MP3 500. Around 3500rpm I hear a clicking sound. Performance is not affected, but it is concerning. Does anyone know what that is? Is it normal for CVTs? Thanks for the help...
@jimscoot avatar
PX 150
@jimscoot avatar
PX 150
My LX150ie makes a clicking/rattle, light throttle cruising, hot engine.
It comes and goes..sort of used to it now. I tried a slightly thicker grade of oil which helped alot.
@witch avatar
Moderatrice Strega
Moderatrice Strega
@witch avatar
I have a clicking coming from my front end, too.
At least in my case, it's not a huge problem. Turns out it's just the fact that the fork cover fasteners keep falling off. The only one that stays on is the small Phillips-head screw visible on the outside. The two "interior" fasteners have been replaced multiple times, to no avail. The clicks happen when I hit a slight bump or change in the roadway, which makes the plastic bang together, and I only hear it when I'm going slow enough that there's little wind noise (although now that I have a tall screen, that's most of the time).
Couldn't hurt to check.
I'm hoping a permanent solution can be found when I go to get my front tire changed. It's a PITA to get up in that area with the front wheel in place.
Strangely enough, I've only really heard this being a problem amongst GTVs. I know the front fender is a bit different from the GT/GTS, but I see no reason for the fork cover or its fasteners to be. So it's either a problem unique to GTVs, or the GT and GTS owners don't talk about it as much.
@olibear avatar
gts 250ie
@olibear avatar
gts 250ie
mee too!
i just noticed it today. clicking sound is present around 25mph then again about 35mph. i tried to shake the scoot when i got home but unable to reproduce the sound. after reading witch's post, i'm gonna check the plastics up front. it does have a similar sound to that of a plastic knife running across a wrought iron fence.
@trax06 avatar
GT200
@trax06 avatar
GT200
you can hear alot of stuff without the helmet on, try rolling down the hill with engine off it sounds like the scoot is sick.
@olibear avatar
gts 250ie
@olibear avatar
gts 250ie
well, nothing rubbing in any way whatsoever up front. i did however change the oil, oil filter and recharged the air filter. when idling afterward to make sure i put everything back, i noticed the clammering sound again Crying or Very sad emoticon. opened the seat and removed the pet carrier. while on the throttle slightly (wish i had a tachometer) i could reproduce the sound everytime! its more of like a quick thug but repeated a few times. its almost like its dieseling. the oil light on the cluster is not illuminated and the dip stick reads fine, so i think the level is fine. added motul 5w40 that the dealer sold me, so that should be fine too.
any thoughts?
@scooter_cruiser avatar
bv 500
bv 500
You might be hearing the fuel injector if your scoot is fuel injection. My apologies in advance if that is not the case.
@witch avatar
Moderatrice Strega
Moderatrice Strega
@witch avatar
If it's cold out and the bike isn't warmed up, I occasionally hear my rollers rattle upon hard accelleration. Sounds awful, but it's nothing to worry about, and doesn't even happen consistantly. Dunno if that's the issue, but it's a possibility.
@raputtak avatar
@raputtak avatar
Ahem! I had the same problem in my Rolls. Turned out to be the clock.
@tor2ga avatar
@tor2ga avatar
Did they charge you to repair it?
GT 200, Faro Basso, Cosa, VS5
It may be coming from your exhaust, when they are loose they make ticking noise.
@raputtak avatar
@raputtak avatar
It was a Rolls Canardly. It Rolls down the hill and Canardly get up the other side.
Laughing emoticon Laughing emoticon Laughing emoticon
Oh to act fourteen again!
@olibear avatar
gts 250ie
@olibear avatar
gts 250ie
went for a 20+ mile ride today and the sound is still there. don't think its the injector or the muffler. unable to reproduce the sound while shaking the scoot, but its prevalent on acceleration. its almost like something is loose enough to rattle around at certain speeds.
@olibear avatar
gts 250ie
@olibear avatar
gts 250ie
further troubleshooting lead me to check the hub oil and it was WAAAY LOW! It didn't even register on the dip stick! so, i topped it off at the local auto parts store then drove home and the clunking is still there. albiet the ride was only about 4 miles (told you it was a local store)!
@olibear avatar
gts 250ie
@olibear avatar
gts 250ie
well i changed out the rollers & cvt belt. ride is better and don't hear the marbles anymore! the variator plates show a little bit of wear, but not too bad.
[ Time: 0.0139s ][ Queries: 3 (0.0075s) ][ live ][ 343 ][ ThingOne ]
