@wasp521 avatar
'62 vespa vnb 125 (cushman import"
@wasp521 avatar
Well, here goes; I'm new to the world of Vespas and have lots of questions, though I won't hit everyone with all of them at once.
First, is my Vespa a Large frame or a Small frame? ('62 VNB 125CC)
Second, will side cowlings from a '64 allstate VBB fit my scooter? Thanks in advance.
http://www.scooterhelp.com/scooters/VNB3T.125.html
Large frame. I'm not sure about the cowls...
(Welcome to MV.)
@killo avatar
I have a few scooters....
@killo avatar
Large frame scooter. The Allstate cowls should fit with no problem.
@vezpa avatar
@vezpa avatar
+1
But there is no allstate VBB It's either a Allstate or a VBB.
For example the 64 Allstate is basically the same as a 64 VNB.
@wasp521 avatar
@wasp521 avatar
Thanks for the response, I was worried I might have screwed up buying the Allstate cowls. I just needed the engine cowl, as mine looks like it has been dumped, crushed, and hammered out several times. I wound up getting a pair including the lock, which I needed anyway.
@rover_eric avatar
@rover_eric avatar
Those cowls are readily available... they probably made a million of the VBB / VNB / Allstate body style.
And the indians continued to press them out when the italians stopped.
[ Time: 0.0161s ][ Queries: 3 (0.0100s) ][ live ][ 343 ][ ThingOne ]
