@yellowscoot avatar
LX150
@yellowscoot avatar
LX150
Hello. My rear brakes do not engage unless I squeeze left lever all the way.
How can I adjust it so it started breaking sooner?
Thank you all.
@dougl avatar
El Macho
Vespa GTS 310
El Macho
@dougl avatar
Vespa GTS 310
On the opposite side of the scooter from the exhaust at the rear wheel beneath the engine there is a cable. Undo the locknut at the front of the lever and then turn the outer nut clockwise, until you get the brake feel the way you want it. The wheel should still turn with the brake off. Both 10mm wrench I think.
@zippy avatar
Dragon Red LX 150 (Hillary)
@zippy avatar
Remember to tighten down the lock nut when finished.
Paul
Maybe your brake pads/shoes are worn out.
@oopsclunkthud avatar
1:3
I try to match the adjustment of the rear to match the feel of the front. Sitting on the bike, eyes closed, pull both till they just get firm. Adjust the rear in or out so they feel the same at that "firm" point.
There's also an indicator on the arm going into the cases to show when the shoes need to be replaced.
GTS 250ie YELLOW N WHITE,Giallo Lime
Re: Brake lever adjustment
Thank you all.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Welcome Yellow Scoot, what type of scooter do you ride? 8)
1:3
Thank you all.
well, let's see...
maybe... an lx150
maybe... an lx150
@yellowscoot avatar
LX150
@yellowscoot avatar
LX150
Thank you, All.
Could not get to it last night, but definitely will do it this weekend.
It is LX150 and only has 1,600 miles on it. Do not think pads suddenly worn out, just that nut may be lose.
Thanks again!
@copper_dolphin avatar
LX150 Darling Plum; GTS 250 Dragon Red; Honda Big Ruckus Demented Bastard
Hello YellowScoot
I figured a picture was worth a thousand words. This is what your looking for under the trans-cover on the left side of the scoot.
This should clear it up.  Will take you but a few minutes to get it adjusted.
⬆️    About 9 months elapsed    ⬇️
@max_slaine avatar
2005 ET4
@max_slaine avatar
2005 ET4
I'm looking to adjust my brake levers, this explains the rear adjustment. Is there a similar one on the front wheel as well that I can adjust as well?
@drewteague avatar
@drewteague avatar
No, the front brake is a hydraulic disc brake. The only way to "adjust" it is by bleeding out the system. Piaggio recommends a brake fluid flush every 2 years, so it's likely that your ET is due.
@max_slaine avatar
2005 ET4
@max_slaine avatar
2005 ET4
Okay got it. Thanks for the help.
@max_slaine avatar
2005 ET4
@max_slaine avatar
2005 ET4
Just made the adjustment to my rear brake and it was easy. Thanks for the advice.
@marcomilano77 avatar
GT200
GT200
I have a GT200...does it work on my rear brake lever as well?? lever became loser after laying down for a nice parking of a car...not sure what happened but it doesn't brake for the fisrt half...
Thanks!
@mikenpalsie avatar
gt200
@mikenpalsie avatar
gt200
the gt200 has hydralic brakes, front and back, sounds like they may need to be bled, also check the thicness of your pads.
@silver_streak avatar
... and whether the perch to which the brake lever attaches has been loosened from the handlebar.
GT200
GT200
yeah I got the check the handlebar cause I did the bleeding but didn't change that much... it still has half the way without engaging
Thanks!
⬆️    About 4 years elapsed    ⬇️
Vespa LX150
Vespa LX150
I had this "tightened" at my last oil change. It worked well for 3 months but now the front brake is now so loose it does nothing again. Does this mean I have a leak in that system? I'd appreciate any information you can arm with me before I go back to the repair shop.
Thanks!
-Alek
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Probably. Could be internal in the master if you're not seeing fluid.
[ Time: 0.0149s ][ Queries: 4 (0.0081s) ][ live ][ 343 ][ ThingOne ]
