Hi everyone,
i'm the proud owner of a Vespa LX 50 2t on an 08 plate.
I was on my way to college the other day and notices as i got to around 40 mph at one point the revs dropped and i lost some speed, this lasted about 2 seconds and then continued as normal.
After college that day, i was leaving and after 1 mile, the revs dropped and the engine cut out (making a similar sound to as when the ignition it switched off when riding).
I've spend two days trying to start it again and have been unsuccessful.
I have checked for any blockages involving the petrol tank or oil tank and have found no problem.
Any other suggestions will be much appriciated
@oneprairiepiston avatar
LX150
LX150
Sounds like the descriptions I have heard of the rev limiter.
Have you had that happen at 30 or 35 -- or just at the top end?
@messycoloring avatar
LX 150
LX 150
well you might take a look at these threads
If you over fill your gas tank or have laid the scooter on it's side
https://modernvespa.com/forum/wiki-evap
https://modernvespa.com/forum/topic15443
@vezpa avatar
@vezpa avatar
How old is your gas? I would recommend draining it and refilling. Check to make sure your battery is charged and the cables are snug on the battery.
2009 Piaggio Fly 150
Hmm...this sounds just like the problem I just spent 170 bucks fixing. Well, at least now I know how to go about checking/fixing it myself.
Check the plug cap - it may be loose or the cable may be badly connected inside it. The fault sounds electrical, not fuel related.
Thanks everyone, however, all the fuel and battery comments, i have already tried this and have had no luck. I have also checked the plug and given it a good clean etc. However the problem still occures.
I do agree, i think the problem is electrical as i have tried all the mechanical things i can think of, or find online!
[ Time: 0.0091s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
