@nrycro avatar
Vespa LX 150, '59 VBA
@nrycro avatar
Stupid newb question, but do people pre-mix the gas and oil in a container before putting it in the tank or do people just add the gas to the tank and then add the oil and let the forces on the liquid when accelerating, braking, turning, do the mixing for you..
(assuming you don't have auto mixing etc)
Re: mixing the gas
I fill the tank with gas, measure the appropriate amount of 2-stroke oil, dump it in, start it up and ride.
Some people stand there and shake their tanks - I never bother with that - the stuff is made to mix in gasoline and it will do just fine on its own.
@nrycro avatar
@nrycro avatar
mix and slosh it is...
cheers!
@nickandsusan avatar
65 Sprint, 2008 150S
I used to have premix premixed in a jug at home, but it got to be a pain to fill the darn thing up..
I just fill up at the petrol station and add oil accordingly
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
i add oil first and then add the gas. the force of the gas hitting the tank mixes it up for me.
Actually it's engineered to mix with the gas regardless of whether you shake it up, you put in oil first, gas first, or standing on your head...
but whatever makes people feel better and works for them
@jamesjohn avatar
@jamesjohn avatar
well it does make me feel better. last thing i want at this point is a seize. i just hit 400 miles on the new top end.
@mdchanic avatar
GS 160 /4
@mdchanic avatar
GS 160 /4
No need to manually agitate.
Try it in a more or less clear container some time (a dry empty milk container, for instance). Just our in the oil and a moment later, it's all the same color.
- Eric
@jamesjohn avatar
@jamesjohn avatar
i understand...but that does nothing to make me wonder if i didn't what would happen? my world would come crashing down! and i just cant have that.
@jeremy_w avatar
79 P200e, 81 100 Sport
@jeremy_w avatar
I keep a 2.5 gallon jug mixed up at home and fill up from there.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
i turn off the tap fill with petrol then add 2% then give the scoot a shake turn tap back on and ride ....... i have a bike tank with tunnel the caps on one side and the taps on the other .... better to be safe than
@nrycro avatar
@nrycro avatar
I like the idea of testing the mixing process in a clear container. Nothing like a home made science experiment!
[ Time: 0.0112s ][ Queries: 3 (0.0024s) ][ live ][ 343 ][ ThingOne ]
