Just curious... thinking about doing this to my buddy and my GS160 :
1) removing the load balanced lighting coils from the stator, installing the dual 12v bajaj coil setup ( $24 from scooterworks ) ...with a single 12v output
2) installing the scooterworks EIK harness
3) running a 12v regulator ( or P200 5 pole rect. if i'm doing a battery )
upsides : ability to run 12v bulbs, abililty to potentially charge a 12v battery and run 12v accessories ( read, stebel nautilus under the spare tire cowl )
downsides: loss of load balanced system means all devices share single power source thus dim when additional load is added... headlight dims when you step on the brake pedal, etc.
