>You're saying you smoked your belt, I think your guess is wrong. I think you smoked the clutch.
I went up a really steep, rough dirt road that I had to go real slow. When I got to the top if felt like the real wheel was spinning in the grass, it was the clutch slipping, I could smell clutch.
Also, nothing against
www.scoottrap.com, but why are you buying a aftermarket belt that has been proven to not last as long as the OEM belt???
There have been multiple aftermarket belt failures at around 3,000 miles. Get the OEM belt from the dealer that will be doing the installing.
Wayne, thanks but a bit late, I already placed the order. I had asked about this in another thread ("Stuck in the mud," <https://modernvespa.com/forum/topic52693?highlight=>) and the only suggestion (from OAD) was that I had glazed the belt. Being a chain-and-sprocket motorcycle guy, this is all new to me. A conventional clutch, submerged in oil, will smell burnt but never actually smoke (well, unless you REALLY overdid it!) but I did ask about my clutch. And I wonder if this is related to my "wooshing" sound. I'll try to record the sound but that's going to be an interesting endevour. The closest thing I can compare it to is the gurgling/sucking sound a garbage disposal makes, but not nearly as loud. I don't have the classic symptom of a bad clutch/torque converter - maxing the throttle and seeing the tach redline while the vehicle slowly accelerates - but again, I don't know if that sort of experience applies to the MP3.
I have to say that if an MP3 clutch will experience damage from a minute or two of spinning the rear wheel in mud, that is not a very good recommendation for the vehicle (or any vehicle that behaves that way), far more delicate than a wet plate clutch or torque converter. I witnessed a car clutch being burned out (watching someone learn how to start from a stop on a hill), but the tires were on dry pavement, not spinning; and it is standard procedure to get a rear-wheel drive car out of mud or icey snow by applying slight emergency brake while goosing the gas, and I've never damaged a car clutch or automatic tranny that way either.
Other than redlining while applying full rear brake, I don't think I could burn out a conventional clutch on a motorcycle if I tried. I guess they don't use centrifugal clutches in any dirt bikes!
As far as the differences between belts, I did inquire what you get for the different prices. Whether fact or fiction, Scootertrap says the cheaper of the 3rd parties "doesn't loosen as much as OEM" and I still don't know what's supposed to be more desireable about their most expensive 3rd party belt.
I'm going to go out on a limb here and presume that the clutch and the variator are two different components, but the clutch can be checked during the variator replacement, yes? How much did your clutch cost to repair?
