@tomorrowmatters avatar
Red S150
Red S150
My partner just bought a white S150 and this I noticed this on the frame.
it lookes like Vespa 'dips' the frame and all to paint it, and there was an air pocket at this location.
I sent an email to the store I bought it from, and they said they will get back to me tomorrow, I'll be there tomorrrow to pick up my Vespa.
what you guys think? is it repairable? or should we try and get a new/different scooter.
or do we even need to worry about this?
This is the damaged side
and the opposite side for comparison
GTS 250ie YELLOW N WHITE,Giallo Lime
Re: Any one have paint issues?
xxxxxxxxxxxxxxxxxxx
It looks like the weld job was done wrong, I hope you didn't buy a harvested scooter that had been in a wreck and then fix up for sale later, go on line and check the VIN number to make sure it's okay.
http://www.pronto-net.com/vin_app/vin.php
Good luck and I hope I am wrong about it being in a wreck before. 8)
PX200E X 2
PX200E X 2
I had a yellow gts that had a a paint flaw so bad it looked like a two year old took a paint brush to it, my dealer was a stand up guy and even though piaggio refused to take it back he traded me even for an mp3. No doubt he was eager to move the three wheeler but it was either that or have them strip a brand new scoot in the middle of riding season and send it to some paint shop
The Host with the Toast
If the scooters where new when and how long did it take to flaw to develop?
Vespa paint is 2 stage paint and can be fixed very easy by spaying a clear coat on it. the white Vespa looks like a bad weld.
@gogogordy avatar
Reprehensible Misinformant
@gogogordy avatar
xxxxxxxxxxxxxxxxxxx
Thats not actually a weld, it's seam sealer...a putty-like paste. The spot welds are in past that seam, where the metal is bent to make flat contact with the other piece. You'd have to remove the floorboard to see that.
It appears as if thats just a bad spot in the seam sealer (putty) to my untrained eyes.
Red S150
Red S150
xxxxxxxxxxxxxxxxxxx
I agree, its not a weld. I can tell that much. Its hard to take a picture that can show the detail. Its missing paint what you see is a lack of paint not a crack in the metal or a bad weld.
We did buy it new two weeks ago, came with a "certificate of origin" so I don't think it was wrecked or previously registered at least.
I only noticed this a few days ago, I saw that the dealer didn't completely remove the protective film from the silver trim...when I pulled it off I noticed it.
@gogogordy avatar
@gogogordy avatar
xxxxxxxxxxxxxxxxxxx
They fill in seams prior to painting with that goo, and paint over it. (Manufacturers use it in automobiles too....typically in trunks and floorboards) There's a small bead of that in the seam behind the seat that runs from the fuel tank, towards the rear tire. And elsewhere.
I consider it strictly cosmetic, and not a sign of previous damage, etc. Would I want it rectified somehow? Yes. No question.
@dougandmichelle avatar
None. Maybe again someday when Michelle won't worry.
Both my old GT and now my GTS have done this. I just used touch up paint and filled it in some and called it good.
@gogogordy avatar
@gogogordy avatar
That "stuff" tends to dry-up and shrink some with age and use....good maintenance item you do for it! Then, let it dry, and take a ride
@1969lambretta avatar
gts 125 super
gts 125 super
If you bought this scooter new just take it back
and demand it be put right, personally i would
not except anything less than a new scooter in
it's place. If it was second hand see if your dealer
will repair it for free and stand your ground,
do not give in until you get what you want! I
would not leave until it was sorted!!!
Like the others, I believe it's body putty, they used to seal the seem. This should be touched up to prevent water (air really) from infiltrating the seam and rusting it.
It's probably just a photo thing, but it appears that the trim that covers the end of the molding is not pristine.
@astromags avatar
@astromags avatar
It's under warranty? Don't sweat it. Just have them fix it.
@chetwynder avatar
Baart-less
@chetwynder avatar
Baart-less
I'm very forgiving when it comes to minor imperfections and such but to me that's simply inexcusable for a brand new machine. Seeing things like that (and reading about GTS 300 paint and rust issues in other threads) makes me wonder about quality control at Piaggio....
Dave
@dougl avatar
El Macho
Vespa GTS 310
El Macho
@dougl avatar
Vespa GTS 310
All the models have a flexible sealant beneath that particular joint. It is painted over and the paint will crack if you press on it. It's annoying but I would just live with it. Recent Piaggio quality control has taken a nose dive in my opinion. The 2000 to 2004 Vespas were much better built.
[ Time: 0.0110s ][ Queries: 4 (0.0044s) ][ live ][ 343 ][ ThingOne ]
