@tairuhn avatar
LX50
@tairuhn avatar
LX50
Hi all,
I've been waiting on a battery relay from my scooter shop and, in the meantime, have been kick-starting my LX50. I feel that I am pretty darn good at it, and usually get it started on the first kick.
HOWEVER--after riding it on Tuesday night, I couldn't get it started on Wednesday...nor this morning. I don't know WHAT is going on and it is SO FUCKING FRUSTRATING! ...as I'm sure you all know. Is this just me not getting it right? Is there a reason that it wouldn't kick start at all?
I appreciate any help, so thanks in advance!
@zippy avatar
Dragon Red LX 150 (Hillary)
@zippy avatar
IMHO
If the kick starter is anything like the LX-150 I would wait for the relay and
not kick it. The damage to the cover would cost a lot more in money and
wait time.
Paul
@smallstate avatar
@smallstate avatar
you could bumpstart it until you get it fixed.
@smallstate avatar
@smallstate avatar
can you bumpstart a scooter without a clutch?
@menhir avatar
@menhir avatar
First...cut down on the caffeine a bit.... Razz emoticon
Like I'm one to talk...harsh language and frustration is usually my own first course of action, too. Razz emoticon
Since it sounds like you already know how to use the kick-start (brakes applied and all that), what is it actually doing when you try?
Nothing?
Sputtering but not fully starting?
I've heard some say that you can't kick-start it if the battery is totally dead and/or gone. I don't know that for sure.
One thing for sure...you are risking damage to the CVT cover if you go at it too furiously. Be careful or you'll really have something to swear about.
Let us know exactly what it is or isn't doing.
@menhir avatar
@menhir avatar
To follow up on my own post...I almost forgot:
If it feels like the scooter is almost-but-not-quite starting, try applying the throttle wide-open as you kick.
Previous warnings still apply, though.
@silver_streak avatar
No.
It HAS a clutch, actually, but it is centrifugal... and there is no way it can be engaged without getting a running engine up well above idle speed.
@tairuhn avatar
LX50
@tairuhn avatar
LX50
thanks guys...it sounds like it is 'shuddering,' sort of. not quite almost-starting but also not totally dead. i did try to open the throttle all the way, without luck.
i would know if i cracked the casing, right? and you think that it is more likely that my kicking is not as on-point as usual instead of an engine problem?
and you are right about the caffeine...at least i don't have to go to work today!
@menhir avatar
@menhir avatar
You would see it, for sure.
At this point I would take Zippy's good advice and wait for the relay.
Even if you do get it kick-started, you're going to have to do it all over again when you get to were you are going. It's not fun not riding, I know, buy you are risking more than you gain.
Good luck.
@starreem avatar
@starreem avatar
Maybe you've just flooded it?
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
When it doesn't start, have you checked to see if it is because you are getting no spark? I had my CDI go, and when they do it often results in INTERMITTENT lack of spark, which makes it so frustrating to diagnose... your instinct would be "it never sparks with a bad CDI"
Check for spark when it doesn't work - the engine will make all sorts of noise when turning over which has nothing to do with whether gas is actually getting burned.
@ronin avatar
Vespa Rally 180 BMW R1150R Suzuki Burgman 400
@ronin avatar
And of course the obvious... not that I've done it or anything but be sure, and I mean really sure, that the "kill" switch is in the "run" position. It happens!
Edit - and also hold a brake lever! Not that it matters for you, but Hondas also have a no-start interlock when the stand is in the up position. Makes sense I guess, but it's one more thing to go wacky when you least need it.
@scooterraton avatar
2 - Many
2 - Many
Silver Streak wrote:
No.
I think you knew what smallstate meant.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
The brake lever only matters when starting with the key. The kick start doesn't require it being held.
No.
I think I know what Smallstate meant, but I sure as hell don't know what it is that you are implying.
@scootmom avatar
'09 BV250, '02 ET2 '07 LX150
@scootmom avatar
[ I had my CDI go, and when they do it often results in INTERMITTENT lack of spark, which makes it so frustrating to diagnose... your instinct would be "it never sparks with a bad CDI"
Check for spark when it doesn't work - the engine will make all sorts of noise when turning over which has nothing to do with whether gas is actually getting burned.[/quote]
Ok, I'm green....how do you test to see if your spark plug is, um, "sparking"?? My scoot has not been starting intermittantly for 3 years now and it's making me crazy! I think I replaced the CDI last summer and it ran good for a while, but now, it's not..... Sometimes you can get it to catch with the kick starter, but generally,not. (I also had to walk 2 miles to lunch yesterday because the scoot wouldn't start, and then back to work, only to have it refuse to start after work, too.)
Help? It tries to start but just doesn't "catch".
AND, why the heck do my "quotes" not show up in the boxes?
@harvey avatar
@harvey avatar
I think you may have had an extra [ to confuse the software- Check this post by 'quoting' it and use Preview to see what it looks like.
Harvey
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
To check for a spark, you
1) unscrew the spark plug and remove it from the cylinder.
2) then you reattach the HT wire to it
3) switch the vehicle to "on" as you normally would to start.
4) ground the spark plug on something - usually the outside of the cylinder itself. To "ground" it you touch the metal rim of the spark plug (the part with the threads) to the cylinder.
5) attempt to start the scooter with your method of choice - kickstart or button (again, with ignition switches and everything all on)
When doing this, wear good thick gloves and don't touch the metal of the spark plug itself! Hold the HT wire or rubber part of the cap to press the plug against the cylinder to avoid shock.
You should see a nice strong spark at the tip of the plug when attempting to start. Blue = very nice. Also, ideally the spark should be nice and centered in the electrode and fairly consistent in how it jumps, if not your plug might be dirty or worn.
The key issue I ran into with my bad CDI is that whenever my mechanic tested the scooter it would start just fine. Therefore, testing for spark didn't do anything... it was sparking fine. But without fail when I'd take it home it would act up again :-p finally I got it to not start for them, and we were able to pin that to a lack of spark.
I was very surprised to learn that a bad CDI could result in intermittent function like this, but the mechanic said it is not uncommon, so it is worth checking for a spark when the scoot ISN'T starting
For me it would usually start right back up if turned off. But if it sat for a half hour or more I was toast... could kick myself hoarse (whatever that means )
Anyway, just some experience to share, could be pertinent to intermittent starting difficulties
@scootmom avatar
@scootmom avatar
Ah ha!! This spark plug issue may be just what I need...I know they replaced it last summer when I had the CDI replaced, but.... it would be just my luck for it not to be working. The problem is VERY intermittant, and often impossible to prove when I have it into the shop.
About the quotes. The [ is put on the script when I hit "quote", I don't put them on. Sometimes I get boxes and sometimes, not. I did use the preview, that's how I knew it "did it again" when I went back to post the "why".
Maybe I'm cursed.....
@tairuhn avatar
LX50
@tairuhn avatar
LX50
Hey guys--thanks for the help. This is the OP, and I charged up my battery before checking the sparkplugs just to check--and while just trying to kickstart it again my scoot just started smoking from the electrical compartment--where the faulty battery relay is. And smelling like burning wires.
Definitely not good...
@zippy avatar
@zippy avatar
Oh Shit !!!
Paul
@copper_dolphin avatar
LX150 Darling Plum; GTS 250 Dragon Red; Honda Big Ruckus Demented Bastard
Something does not smell right.... What ever was smoking, was probably bad and why you could not get it started. Sounds like something shorted out and now is burned up. I think your problems have gotten worse... sorry..
@scootmom avatar
@scootmom avatar
Hmmm. Mine was having problems starting, then suddenly started leaking oil and blowing white smoke when it would start....I decided to let the dealer that allegedly"fixed" it exchange it for a 09 BV250. I'm much happier, and have far fewer problems!
@thisare avatar
ET4 150 (with LX mirrors)
@thisare avatar
and make sure the key is in the correct position... the number of times (well twice actually, but it only happens when people are watching) that I have been furiously kicking only to notice that the key hasn't been turned to the correct position
[ Time: 0.0221s ][ Queries: 3 (0.0070s) ][ live ][ 339 ][ ThingOne ]
