px150
px150
How do you replace a oil sight glass on a px150
Moved to Not So Modern section.
nothing at all
nothing at all
you can pull the tank and replace it that way, being carefull when reinstalling tank
i cheated and sucked the oil out
then removed the rubber gromet around the glass
i then gently grabed the old glass with rubber glove in channel locks and then replaced with good glass the same way
ridiculous but worked
recommend the removal of tank
its good every now and then to get in there and clean the bottom of tank cavity anyway
px150
px150
I was hoping there would be a way to remove the sight glass without removing the tank. thanks for your input
@steveinsac avatar
2007 GT200 1979 P200E 1980 P200E 2011 Triumph America
@steveinsac avatar
Nice trick Jimmy. I agree that you should take the tank out also just for the experience. But now that I've done it quite a few times I like the challenge of "Take out wrenched ankle" (Milton Bradley's Operation) Razz emoticon
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
its not so hard getting the tank out .... unbolt turn tap so it points up then swing it back and up.... the fun bit is putting it back with the floppy tap Razz emoticon
nothing at all
nothing at all
i think i was more put off by having to disconnect the hoses as well
pull carb lid
disco hoses
unbolt tank
pull tank out competely
glass
put it all back
so i thought i would try it another way, oil was only just showing in old glass
put a 4x4 under the stand and wala, no oil in glass Nerd emoticon
@tor2ga avatar
@tor2ga avatar
Tie a light cord onto the tap handle about 4 feet long. Put that through the hole before you start to lower the tank(s) down. Use the cord to guide the tap handle through the hole as you slip the tanks down. Easy.
@chad avatar
Olivia Newton-John
ET4, Stella, Serie Americana, p200, VBB, VNB
Olivia Newton-John
@chad avatar
i never found it hard to get the tap back through, hat i always thought was a bitch was getting the sight gless down that last 2 or 3 inches. it always rubs against the body and makes it hard to get back in. i'be tried wrapping it with electrical tape, etc. but i still haven't found an 'easy' way to do it.
@vezpa avatar
@vezpa avatar
I'm glad I don't have the sight glass. they break so easy it's rediculous. When I worked at Genuine Scooters we warrantied at LEAST 3 everyday for the Stella. People crack them kicking with their heels. I would just remove the damn thing altogether and keep it filled.
[ Time: 0.0115s ][ Queries: 3 (0.0048s) ][ live ][ 343 ][ ThingOne ]
