@zwerski avatar
@zwerski avatar
How many amps does the stock GT horn circuit push? I picked up a new honker at a garage sale yesterday. Works fine on the Jeep, but no dice on the scoot. I'm thinking the stock circuit isn't pushing enough juice for the new horn.
@tor2ga avatar
@tor2ga avatar
The short answer is, "Not much." What kind of horn did you get? You probably need a relay and some 12AWG to the battery.
@tb avatar
@tb avatar
Check if it needs a relay switch...since there is no information on the horn that you have it's hard to make a recommendation.
If you picked up new (i.e. Stebel or Wolo Bad Boy) a relay switch is included to complete proper install.
Re: GT200 horn circuit ampereage
IIRC, about 2A max, usually fused at 7.5A. I wouldn't trust the cables to supply more than about 2A without dropping too many volts.
My advice, regardless of the type of after-market horn, *always* use a separate relay. Takes not much longer to install, but forestalls all sorts of problems down the line.
@zwerski avatar
@zwerski avatar
Bummer. I wasn't in the mood to change the horn out until I came across the cheap garage sale one. However, I don't want to get into running wires, wiring relays, replacing switches, etc.
My wife and I have a busy 11-month old and getting a good amount of alone time with any one project before I need to tap in for a shift change is tough.
I don't want or need a Stebel Nautilus (yet), but would entertain more of an annoyed "honk" than the friendly "meemp" I get with my current horn. Are there any recommendations for "plug and play" horn options?
@zwerski avatar
@zwerski avatar
Never mind. I used the search function. Someone moved the reminder sticky.
[ Time: 0.0169s ][ Queries: 3 (0.0025s) ][ live ][ 343 ][ ThingOne ]
