hi, i was wondering if any1 could help me with the problem i have with my ET2, i am gettting a metal rubbing noise from rear wheel, the noise sounds like its coming from inside the crank case. it is causing the wheel not to free role as it a should ....HELP !
@vezpa avatar
@vezpa avatar
Re: Problem with VESPA ET2
Are your rear brakes seized up? Stuck? Rusty? You can also open up the case and see if you have a broken belt or see if somethign else has broken like the clutch and somehow lodged itself in there causing this problem.
[ Time: 0.0085s ][ Queries: 3 (0.0024s) ][ live ][ 343 ][ ThingOne ]
