@mike_m avatar
1986 Vespa PX 125E, Pinasco 177
@mike_m avatar
Yesterday my brake pedal went to the floor. It still works, but it has to go right to the floor. This happened suddenly. Has the cable come loose and need adjusting?
@scooterraton avatar
2 - Many
2 - Many
Sounds like it either needs major adjustment or it is about to break. Sometimes cables will begin to fray and stretch before the break. I would check it out right away.
@koenig_blues avatar
i know there were a term of 'push the pedal to the metal" but in ur case its not as cool as that, u need to check or even change the brake cable as its indicate either its loosen or a inch close to snap it self Razz emoticon
@mike_m avatar
@mike_m avatar
Is the rear brake cable difficult to change? I've got a spare here. Can I just slide it through the outer
@airfin avatar
some Vespas, some Lambrettas
@airfin avatar
Its the easiest cable to change in my opinion. Undo it on the engine side - then unbolt the pedal. Pull the old inner cable out and pull it off the pedal. Reverse the steps for installation. Its not trick at all. Make sure the oterh part of the cable is in good shape - and lube the inner on install and your good to go.
@mike_m avatar
@mike_m avatar
So, the cable seems to be pulling the arm on the back as forward as it will go when the pedal is pushed, but there is no resistance. Is it possible something is wrong with the back brake? Is there something inside that may have come loose?
nothing at all
nothing at all
this recently happened on my et3
i did'nt tighten the clasp on the pedal end tight enough
dropped the pedal, reinserted, tightened, bolted the pedal back in, adjusted, good as new
thats funny, it was new, just not tight Razz emoticon
@mike_m avatar
@mike_m avatar
I think your problem may be slightly different. I dropped the pedal and everything looks connected fine. The pedal is going right to the floor pulling the cable, which results in pulling the brake arm all the way forward with no resistance from the brakes.
Is it possible a spring or something inside the brake area has given up??
nothing at all
nothing at all
in that case, yes
you will have to pull the rear hub
be sure to replace the cotter pin with a new one!
@mike_m avatar
@mike_m avatar
anyone????
If not, is it safe to ride a mellow 2 miles with only a front brake so that I can take it to my local shop?
@mike_m avatar
@mike_m avatar
Is the rear hub-bolt 22MM and a real pita to undo? What would have been screwed up inside to cause this?
nothing at all
nothing at all
this is a lambretta, but it shows you the spring that may have broke or the brake caliper or
[ Time: 0.0153s ][ Queries: 4 (0.0089s) ][ live ][ 343 ][ ThingOne ]
