@rover_eric avatar
@rover_eric avatar
The next time yours pulls right out of the bike and isn't welded in place from years of rust and dirt, say a little "thank you" prayer to the scooter gods.
I spent hours last night trying to remove mine out of the GS160mk2. It was locked in there so tight even my trusty impact wrench couldn't budge it.
I tried heat, i tried PB blaster, etc. I ended up cutting the hex end off the bolt with a dremel tool, and it's STILL stuck in there...20 broken cutting wheels later.
advice ?
@jeremy_w avatar
79 P200e, 81 100 Sport
@jeremy_w avatar
Re: Swingarm bolt removal
Rover Eric wrote:
...advice ?
Give it to me. Razz emoticon
You need one of those things the guy from "No Country For Old Men" uses to kill people and knock knobs off of doors.
@koenig_blues avatar
sculpture tools and a big hammer Razz emoticon
Perhaps you could push out the remainder with a gear puller.
If a U-shaped grove wore in the bolt, it's going to be difficult.
@louispain avatar
Cosa and P200E
@louispain avatar
Cosa and P200E
Drilled out part of the swinging arm pivot bolt on a 1978 Suzuki GS 1000.
Vespa should be easier it´s a little small bolt
Used some cheap Cobalt drill bits. Small one to start/pilot with and progressively bigger to expand the hole. Plumbers footprints (pipe wrench?) on the other end.
Belted it every now and then with a metal drift and lump hammer. Once the hole was big enough the bolt caved in.
@zwerski avatar
@zwerski avatar
Yeah! "Anton Chigur" the fawker!
@ktmdriver avatar
SS-180 x 1 (dead) SS-180 x1 (3'rd times the charm)SS-90 x 1 GS-160 MK1 x 1 P-200e x1 TV 175 S2
@ktmdriver avatar
Mig weld another axle bolt onto the threaded part, then sledge hammer the extension and that should break it free. Once that has happened, cut the extension off and then use a punch to get the rest out. Regarding using heat, get the Mapp gas out, it's much hotter than propane. Heat before hammering.
@killo avatar
I have a few scooters....
@killo avatar
I had one stuck in my Allstate engine. I cut off the 2 ends of the bolt so I could get the engine out of the frame. Then took a small drill bit and drilled the rubber engine buffers to get the remainder of the bolt out. A total bitch. Then there's replacing the buffers...
@gatekeep avatar
1974 Rally USA 200 1980 P200e
@gatekeep avatar
Yeah, you need to get something to push it though.5lb.sledge ect.
Soke that bitch with Kroil.
Heat too..
I put Never Sieze on all
bigger pain in the ass bolts/studs.
@starreem avatar
@starreem avatar
I had a tough time getting the bolt to move out of my SX150. What eventually worked for me, (and it only worked because there was thread still in the tube) was to remove a nut on one side, and tighten the nut on the other side to get the bolt moving in the tube- like a puller. A bit of back and forth like that eventually got me enough movement to bang it out with a drift pin.
I figured my only other option to get the bolt moving was to weld the nut on one side to get the bolt to turn.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Oh god, mine was SO difficult to get out. It took me hours with a friend. I put a new bolt in and greased it up like a southern frying pan when I reinstalled the engine to try to ward off a similar experience in my future
@chad avatar
Olivia Newton-John
p200, vbb, gt200, px150, vnb
Olivia Newton-John
@chad avatar
Jeremy W wrote:
Rover Eric wrote:
...advice ?
i was totally waiting for that guy to get his ass kicked, and then he just won and walked away.
@valkr1e avatar
1962 Cushman VNB3
@valkr1e avatar
1962 Cushman VNB3
get a hand full of drill bits and get to work. I run into this every time I do suspension or axle work on my A6.. unless you have a week and the good will of the pb blaster gods, it's about the only way.
@oopsclunkthud avatar
1:3
Heat too..
I have been trying to remember the name of "Kroil" for 15 years now. Thank you!
@joshzingzing avatar
i will always say it
eucalyptus oil!
fook knows how to get it in there though.. maybe a syringe
@rover_eric avatar
@rover_eric avatar
i'm intrigued by the notion of a homemade 50/50 mixture of Acetone and Automatic Transmission fluid that Chad posted about recently.
Do a search for Kroil in here for the article he posted out of popular mechanics or whatever that tested the various fluids.
Oh, and still no swingarm love. It took me 2 hours last night to remove the brake pads from the pins they rest on. Lots of propane heat and PB blaster later and i was able to wrest them off with Vice Grips. Backing plate came off, and then i was done for the evening.
nothing at all
nothing at all
eric, am i thinking that the bolt is fused to the sleeves that are part of the rubber bushings in the arm
if thats the case, pouding on it won't make it give because there is no resistance
the rubber is cushening the blow
i would think you have to cut both ends as close to frame as possible and the pry the frame out about an 1/8 inch so the whole arm with bolt still inside drops out
then remove on bench
i don't think beating will beat this one Nerd emoticon
@rover_eric avatar
@rover_eric avatar
Jimmy - i think you're totally right. Good advice.
On the GS160 / SS180, the two bushings on each side have a steel tube inside of them ...they meet in the middle, and the swingarm is completely enclosed, so you have no access to get lube in there to loosen it. I think they moved away from that design on other engines - exposing a window so this wouldn't happen.
Anyways, i think i'm going to hunt around and see if someone has a Sawsall ... put a metal blade on it ( like for hacking out old galvanized plumbing ) and attack it from underneath in the areas between the swingarm and the frame.
At least then i'll have the engine out of the frame and hopefully can hydraulically press out the remnants of the swingarm bolt.
nothing at all
nothing at all
yes
even better than prying frame is to attack between the frame and arm
much better idea
remember pics for the next frustrated soul Razz emoticon
@rover_eric avatar
@rover_eric avatar
Clubmate loaned me a sawzall last night. I'll get hacking here shortly and let you know how it went down.
nothing at all
nothing at all
nail biting Razz emoticon
@scooterraton avatar
2 - Many
2 - Many
This is better than TV!
@rover_eric avatar
@rover_eric avatar
Sawzall got the engine out of the frame in about 20 minutes last night. I flipped the frame upside down and attacked the bolt on either side with a metal saw bit and it worked great.
Got the frame prepped for bead blasting ...so when it comes back we'll see how bad the rust damage is.
vespa sprint veloce p210
Are you considering the swing arm stabilizers for the assembly?
Mine were super tight to put in (two days of prying), but it has updated the steering to acceptable.
Just wondering....
p
@rover_eric avatar
@rover_eric avatar
Hadn't considered it. Have always just used Clauss's urethane engine mounts instead of conventional rubber ones, and like them alot.
The Hot Rod Al stabilizers work amazingly. I can cross three lanes of traffic in the racer with my hands OFF the bars and just flexing an ass cheek.
But as you mentioned they can be a bitch to put in - definitely need help with it - a bottle jack shoved in there and cranked a bit over a day or so will spread the frame enough to fit them in.
I have them both on my sprint, it makes for more vibrations to the hands, but I really do like the stiffened feel to the whole frame. Initial turn ins with this setup give high confidence instead of the usual oh shit moment, followed by braking, which can get tricky on loose stuff.
I also use the longer rear shock bolt, used on P's, with my sebac. I was having grounding out issues, on left turns, but that extra 1/2" has reduced that to almost never. My JL has thanked me, personally.
Its the littlest of things that can seem to make a huge diff.
@gatekeep avatar
@gatekeep avatar
Lol... now that's classic Laughing emoticon
[ Time: 0.0126s ][ Queries: 3 (0.0054s) ][ live ][ 343 ][ ThingOne ]
