Well....I got inspired back on my old post here:
https://modernvespa.com/forum/topic52504
I've decided to build one out of my Sprint. I think that the vintage racer scoots are awesome. So far I have both the cowls cut and most of the rear cut as well. I have a friend that is going to help me gas weld the glove box side that way I can still have a glove box. Also need to re weld 2 of the mounting tabs on the glove box side on the bottom. On the engine side cowl, I'm having him weld a few tabs for mounting. I'm going to run a few flat head allen screw sort of like how the "Corsa Circuito" has it done: http://www.scooter-vespa.eu/V98ccCorsaCircuito.html to help secure the engine side cowl to the frame.
I have plans to only "slightly" trim the front leg shield and floor board.
The front fender I got from Max at Motorsport. I had got these front forks from him that had this cool fender on it. It's just a small motorcycle fender. I trimmed it a little bit and having my friend fabricate a bracket to mount it just above the front tire.
I also just purchased a set of drop bars from Tim Bridges and are from a late model 70's small frame that has the smaller clam shell speedo. I should get it hopefully sometime this week. I also have plans to run the bar end euro style turn signals.
As for the motor, I still have my PX 150 motor with Pinasco exhaust. For budget reasons, I'm only able to get the Pinasco kit at the moment. Hopefully that will get me closer to 70mph which is good enough for the stock brakes.
I also have plans for a adjustable rear shock. The front fork has an upgraded Gabriel front damper. I tried to find a CIF one but couldn't find it.
The paint will be a satin black. When I painted the horn cast a while back, I liked the satin black. SATIN BLACK THE F*CKER!
I'm still deciding to go with either a SIP evo seat or make my own. Either way, it will be low and flat.
Here are just a few pictures so far. I will update more once I get things going again here soon.
⚠️ Last edited by VLBJS1 on UTC; edited 2 times
@hp avatar
@hp avatar
Re: VESPA DE COURSE ET CIRCUIT
btw, I just noticed that SIP has some sweet new adjustable shocks for largeframe Vespas. I hadn't seen these before but they look the business if they ever get them in stock:
http://www.sip-scootershop.com/EN/Products/72000RSB/Shock+absorber+SIP+Performance+V50PVET3125+VNATS150+VBAT4160GS180SSRallyPXT5+rear.aspx
nothing at all
nothing at all
wow, holy galactic, that shock is beautifull
and it's not red and white Nerd emoticon
Well...I have some time. I will keep a look out for them. They look pretty sick..20 adjustable slots... Thanks Hiram
True..it doesn't look like a f*in' candy cane.
nothing at all
nothing at all
candy cane
thats funny Laughing emoticon
@veloce75 avatar
not-so-normal
@veloce75 avatar
not-so-normal
Ugh... is it your Sprint Jason? now it's your time doing metal work
and... Matt Black the F*cker! please
@koenig_blues avatar
wow u really are in ur own project, cant wait to see ur sprint when it done with ur new satin black the f*cker Razz emoticon
god luck mate
@joshzingzing avatar
i'd like to see how you mount that engine cowl when its been cut
ive been wondering how they do it with the p sreies with the back chopped off
[ Time: 0.0098s ][ Queries: 5 (0.0027s) ][ live ][ 343 ][ ThingOne ]
