Im sorry, I tried to search for it but I have no idea what this is called or what its for, can someone let me know? Its full of what im assuming is oil, but why? it was clear before and didnt have anything in it..now its yellow and full of liquid.
May also want to make sure you check what was collected in the bubble resevoir...oil run off from oil filter would be the obvious...but check and make sure it's not fuel...if it is you may want to dry out your air filter.
Fuel can get into your air filter if you overfill your fuel tank.
