I'm off to the powdercoaters again soon, to get some bits and pieces coated satin black. there is a £45 minimum charge, and i don't have much to do, so wanted to know if anyone else out there had any bits and pieces to add to the order and split the cost. A set of wheels might cost a bit extra as they're finicky to do, but anything else - bar ends, transmission cover, etc. etc. - should be fine.
i use Armourtex powdercoaters in Hackney - they do great work (London Scooter Body Shop uses them) and their turnaround time is only a few days. I can pick up the order when it's done as they're right around the corner from me.
Unfortunately we can only get one colour on the same order, so 'any colour you want as long as it's black'. and do bear in mind that plastic parts cannot be powdercoated
