gts 250
gts 250
Hi, New poster here. I have a gts250 and trying to instlall the vespa topcase...I remember seeing a link/post on installing one a while back but forgot to bookmark it. Any help out there. the instructions with the topcase are not very informative. Thanks for any help.
@ukulelegenie avatar
2007 GTS 250ie Yellow, Buddy 125cc White
Ditto for me too. I actually figured it out last night; and then today a friend-rider saw a pic and said I likely should have left the chrome back end piece "UP" instead of installing the base of the top case on it when down
What say you out there?
@yelgib avatar
2008 GTS 250ie
@yelgib avatar
2008 GTS 250ie
Mine came installed with the Scoot, so I posted a pic of what it looks like from the dealer. Looks like my rack is in the down position. Pic below and here is a link I found discussing the install for you. https://modernvespa.com/forum/topic53164?highlight=gts+topcase+install
External inline image provided by member with no explanatory text[/url]
@benito avatar
@benito avatar
The topcase is installed on top of the folding rear rack, thus the folding rack has to be in the folded down position.
@fluffy avatar
Beverly 350 "Mavis"
@fluffy avatar
Beverly 350 "Mavis"
There is a black clamp that holds the rack down, and the top box actually screws into this. The clamp is a bitch to put on (you need 3 hands!) but after that the fitting is easy. Don't forget the lock nuts underneath, to put these on you'll need a long socket. I cant remember what size, but its metric.
@ron avatar
2008 GTS250ie
@ron avatar
2008 GTS250ie
The flip-down part of the rear luggage carrier is not just for looks. It IS the part of the carrier that supports whatever you are carrying - be it a topcase, or just something fastened/tied on to bring home, or whatever. I just installed a topcase on my GTS250 about 3 days ago, and I reversed the springs (which, BTW, was a PIA but doable) so that they would hold the flip-up piece in the down position all the time, and it works perfectly. If those springs were left in their factory installed position, they would be trying to spring the topcase up all the time, pushing it against the stationary part of the rear carrier at an angle (and the topcase is extremely light when empty) and it would look ridiculous. I also used small pieces of double-back tape between the clamps for the topcase base and the chromed rack so it wouldn't be scratched. Good luck with your installation. Once complete, it all looks very good. Sorry, I don't have a pic to show tho.
Thanks! I will post a pic next week after part of my 'top' of the topcase gets painted. I held down the rack with zip ties (which I believe to be the next best invention to duct tape!). I hope that works. I also did something that the Buddy installers did for that topcase: I mounted it about an inch away from the little chrome part that sticks Up behind the seat. I use that as a handle and I can get my fingers around it. I'll show y'all next week.
gts 250
gts 250
Re: gts250 topcase install
Thanks everyone who posted. A friend stopped by today and we figured it out pretty easily. The instructions that came with it were very hard to follow due to the crappy pictures. Had left over parts presumably for the GT installation.
[ Time: 0.0088s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
