Vespa GTS 250
Vespa GTS 250
Does anybody know if there is a PPG color code equivalent for the Nero 94 (Black) paint used for the 2006 Vespa GTS? Or does anybody know which car model uses the same color?
Thanking you in advance for your help.
PPG can match any color you can give them a sample of.
Wayne B
@harvey avatar
@harvey avatar
You could give this a try:
twistngo wrote:
OKay,...here is a back door to the SIKKENS (AKZO NOBEL is the manufacturer) Paint Code Finder.
http://www.qnetonline.nl/cgi-nt/qnet/qnsearch.asp?site=SIKGL
TYPE Piaggio into the Manufacturer line. Then I always grab a color group in the pull down to narrow it down a bit.
Then search. Look for the PIA731 in the list, click on the AKZO NOBEL CODE , and then you got a mix code for your SIKKENS dealer. Most colors use either Autobase, or Autobase Plus, so play with that product pull down menu until you get a code. I have no idea as to the specs on the individual SIKKENS (AKZO NOBEL makes SIKKENS) products so you'll have to ask the paint shop. But I have used this before with success. Most piaggio codes are in here. I would bring in a sample for comparison as well.
Harvey
[ Time: 0.0080s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
