⚠️ Last edited by The Mocker on UTC; edited 1 time
2010 Orange S150
Posts: 3504 Location: Olympia, WA, USA |
The scoot is giving me trouble all of a sudden From a stop it accelerates normally for mere seconds, then hesitates & gets up to 30 veeeeery slowly. Once at speed, acceleration is fine until I stop again. The engine (exhaust?) is also suddenly louder, emitting a spluttering sound. I also heard something hit the road today as I was crossing an intersection before this problem started. It could have been something I ran over or some crucial part falling off the scoot Any ideas or places to start looking?
I have the exact same problem. I looked underneath and realized where the male and female ends attach (forgive me, I don't know the correct terminology) had become loose. I was able to loosen the bracket and push them together. After tightening the bracket the noise was reduced quite a bit. There is still some leaking. I'm wondering if I need a gasket or what I should do? Please help! Thanks
GTV 250 ie Navy Gilera Runner VXR200 Yamaha Fino Sport
Posts: 112 Location: all over |
yeh...your exhaust must not have any "leaks" have it checked...you can loose back pressure...hence the sluggish take off...plus back firing as well...
rochopper wrote: I have the exact same problem. I looked underneath and realized where the male and female ends attach (forgive me, I don't know the correct terminology) had become loose. I was able to loosen the bracket and push them together. After tightening the bracket the noise was reduced quite a bit. There is still some leaking. I'm wondering if I need a gasket or what I should do? Please help! Thanks You can have problems due to it's failure- the exhaust gases can burn though/ damage the mechanicals & wiring. check here for some info: More exhaust problems, exhaust gasket help GTS workshop manual is here: http://manuals.wotmeworry.org.uk/Vespa/GTS250/ If you're not mechanically inclined the gasket itself is around $30-$40 and its a 15 minute job for a dealer to replace (some will do the labor for free, if you're a good customer). Good luck with it! Harvey |
Posts: 2836 Location: Raleigh, NC |
I think all the advice for GTS250 silencers, gaskets and such are not much help for the OP and his LX150. All I can suggest is to look under the scoot to make sure everything is there and nothing is rattling loose.
Posts: 46114 Location: Pleasant Hill, CA |
It's still probably 99% certain it's the graphite exhaust collar though - common to the majority of Piaggio bikes.
Posts: 8758 Location: Annapolis, MD, USA |
jimc wrote: It's still probably 99% certain it's the graphite exhaust collar though - common to the majority of Piaggio bikes. If the exhaust is leaking from something other than a crack or hole in the pipe, I'd wager that either the 8mm cap screws that support the muffler have come loose and caused him to break an exhaust stud (bad news), or that one or both of the 7mm copper-plated nuts has simply backed off (better news, although the nuts are kinda hard to find). Either way, don't ride it until you get it fixed or you can quickly burn a valve. |
2010 Orange S150
Thanks for the advice, I'll try to squeeze myself under there & take a look. The copper nuts are plenty tight. I guess this mechanically disinclined fellow is gonna go see the dealer. I figured it was a compression issue I hope my broke ass can afford the fix.
jimc wrote: Thinks, could be the SAS tube, just had to replace one on the X9 250. |
2010 Orange S150
Soooo, the dealer calls today & tells me I have some worn parts in my clutch that need replacing. My options are a clutch rebuild for 485$ or a new clutch for 535$. After doing some searching here, it seems that a clutch should have a much longer life than this. I ride a 2008 LX150, delivered July 4, 2008 with just under 8000 miles on it. Am I wrong to think that it is awfully soon for this part to wear out? Could it be a defective clutch?
The Mocker wrote: Soooo, the dealer calls today & tells me I have some worn parts in my clutch that need replacing. My options are a clutch rebuild for 485$ or a new clutch for 535$. After doing some searching here, it seems that a clutch should have a much longer life than this. I ride a 2008 LX150, delivered July 4, 2008 with just under 8000 miles on it. Am I wrong to think that it is awfully soon for this part to wear out? Could it be a defective clutch? That does seem like a VERY short life for a clutch if the bike is ridden normally. With those quotes, most of the the price must be in labor charges, as the clutch "innards" should be less than $200, I would think. You can get a Malossi adjustable delta clutch from Scooterwest for $189 as long as the clutch bell is OK. |
I think your dealer is talking out of his arse - if your original descriptions were accurate.
2010 Orange S150
jimc wrote: I think your dealer is talking out of his arse - if your original descriptions were accurate. |
If it's *not* a louder exhaust but a 'strangled sealion' or otherwise screeching clutch, then your dealer could be right - but 8000 miles is far too few for this part to fail if it was of merchantable quality in the first place.
Unless that is you live in a hilly area and use the lazy car-driver's dodge of slipping the clutch on hills (or on automatics letting it 'stay there') while waiting at stops. |
