@wsurandy avatar
2010 MP3 250
@wsurandy avatar
2010 MP3 250
I recently graduated from an LX150 to an MP3. Taking the different braking systems into account, do you regular MP3 riders notice a significant brake grab?
When I'm stopping (for a light, etc.) I seem to stop well short of my target or lurch around a lot -- even when I'm not reaching for the wheel lock.
Never had this problem before with any of my scoots/bikes -- all the way from a Honda VTX1300 to the 150.
Or is it just a matter of practicing and getting used to the MP3?
I don't find then grabby in the slightest - but then I very rarely use full braking power. I always ease off the front brake and start applying the rear when coming to a stop - this way there's no dipping at the front and the tilt-lock is easy to apply with no lurching on take-off.
@gopam avatar
2015 BMW R1200R , 2020 Vespa GTS SuperSport 300 HPE, 2024 Honda ADV 160,
@gopam avatar
I haven't noticed what you are describing. I rode an ET4 before getting my MP3 and the biggest difference was the higher floor board on the MP3. I found I slammed my feet down to the lower floorboard when going back to ride the ET4. Expecting it to be higher like the MP3.
But nothing odd about the brakes.
@g03 avatar
MP3 500 08
@g03 avatar
MP3 500 08
You now are applying two sets of brakes on the front brakes. Like stated above, use rear (some), then slowly apply fronts. (modified) for light coast stopping, not sudden stops like JimC states.
⚠️ Last edited by G03 on UTC; edited 1 time
@wsurandy avatar
2010 MP3 250
@wsurandy avatar
2010 MP3 250
JimC, et al:
Thanks. I think I've been overgrabbing the front brakes. It's time for practice, practice, practice, which is always good.
G03 wrote:
You now are applying two sets of brakes on the front brakes. Like stated above, use rear then slowly apply fronts.
'Tother way round - don't get in the habit of using the rear brake to scrub off speed - firstly it won't work too well, secondly in an emergency you'll lock the rear wheel. Use just the front brakes to slow down normally in a straight line[1] - use some rear as well if an 'emergency'. Rear brakes should normally be used at 10mph or under (or thereabouts) for the final stop.
[1] Using only the rear brake can be useful for steadying the bike in a sharp turn.
@oldspice avatar
'12 BMW R1200RT
@oldspice avatar
'12 BMW R1200RT
I generally use both the front and read in tandem and haven't noticed any grabby-ness. I used to only rarely use the front beake until I took my MC license test and saw the the recommendation was to use both brakes. Using only the front, I could see there being some grabby-ness.
At any rate, your "practice, practice, practice" idea is probably the best. You'll get a feel for it soon enough.
2009 Piaggio MP3 400ie
excellent advice
Excellent advice, Jim. Thanks for that.
[ Time: 0.0107s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
