I searched and found some threads, have tried some things and still no luck.
Sunday night, I had the carb out, replaced the float and needle, adjusted my choke cable so it worked correctly. Buttoned it up and put around 15-20 miles on the thing. It ran perfectly. Before that ride, I also had pulled my plug and it was a textbook coffee and cream.
Once warmed up, the bike had been idling a little high, so I dialed down the idle a little and things seemed great.
Rode it to work on Monday, no problems - perfect again.
Yesterday, I left work for lunch and it bogged down and died. Did this a few times before I realized that I was low on gas. Switched to Reserve and it ran good, but then I couldn't keep it idling.
I played with the mixture screw and idle screw, neither seemed to have any affect on how it ran. Pulled the plug and it was fouled black and oily.
Stuck a new plug in and still can't get it to idle. I currently have the mixture screw at 2 turns out and the idle screw at 2.5 turns out (I believe these are the "standard" settings).
Thoughts?
Thank you
