Greetings,
1779 P200E
In replacing the brakes front and rear, I found a discolored and slightly roughened area on the front axle in the area of contact with the brake drum bearings. It can easily be felt with a fingertip. Somewhere along the line the bearings have done a number on the axle.
How much damage is acceptable? What is a good method to resurface the axle? Can original size bearings be used afterwards?
Thanks for your help.
Jay
