are you supposed to change the preload on the shocks when riding on dirt roads? i always ride on the 3rd setting and the scooter feels like it's gonna break apart, so i would assume a soft suspension would be ideal for this kind of terrain
ouch at 3 you are getting a pretty hard ride all the time!!! Unless you are above 250lbs.... I ride with mine at 1, unless I am loading her down (for a trip) or riding two up..
I just avoid dirt myself but the best setting is highly subjective. I've tried all 4 and found I liked 3 the best. I'm only 155lbs. but I like it stiff
Jim makes a good point. Along with that, I might suggest you reduce your speed when traveling over rocky, or rutted roads. As to the suspension, the adjustments you are referring to only adjust ride height, not spring rate.
