Vespa GTS 300 Super
Vespa GTS 300 Super
I just got my 300 and want to add an accessory outlet, piezo buzzer for the turn signal, and Battery Tender. While I'm handy with the tools and wiring, opening my scooter still scares me because its brand new and I don't want to screw anything up so I would love some help.
@justme avatar
GTV250ie
@justme avatar
GTV250ie
Re: Anyone around NJ care to help me with wiring my GTS300?
I'm not anywhere near NJ, but if you're handy with the electrical stuff, don't let the front of your Vespa intimidate you. Take a look here http://www.wotmeworry.org.uk/manuals/Vespa/ for the manual and see if you don't start to feel a bit more confident.
@boulty avatar
Moderator Australis
Moderator Australis
@boulty avatar
Moved to General Discussion from Proj Reports.
@cincinnati_john avatar
'07 GTS-250ie - sold and gone
Try removing the left knee panel and locate the alarm connector. Only one screw to remove, and easily replaceable.
Vespa GTS 300 Super
Vespa GTS 300 Super
Can you charge with a Battery Tender through the Alarm Connector? If so, what would I need to do to add the accessory port to the Alarm Connector? Don't want to fry anything.
@dougl avatar
El Macho
Vespa GTS 310
El Macho
@dougl avatar
Vespa GTS 310
Yes you can. There is a lovely article written by Cincinatti John in the wiki
GTS250ie : Alarm Connector pin assignments
Turn Signal Beeper and 12V Power Outlet on a GTS
Don't forget the Wiki is your friend!
Doug
[ Time: 0.0101s ][ Queries: 3 (0.0032s) ][ live ][ 343 ][ ThingOne ]
