@slick_89 avatar
1971 Sprint with P200e
@slick_89 avatar
Running a p200 in a 150 sprint veloce frame. The carb box is rubbing against the frame, is this to be expected? As it's seriously affecting the handling at roundabouts.
http://picasaweb.google.co.uk/lh/photo/JKEjAD-ZYJYXkysYh5c43Q?feat=directlink
and
http://picasaweb.google.co.uk/lh/photo/nNnVxDzOcrsKPPtynU5Xhg?feat=directlink
As the auto lube is not in use can I refit the carb into a smaller box, or do I need to take a hammer to the frame? Crying or Very sad emoticon
@tor2ga avatar
@tor2ga avatar
Can you reset the shock/suspension bits so that it is jacked up a little?
@slick_89 avatar
@slick_89 avatar
I've already done that, before I couldn't even get the cover on the frame.
I could raise it further but the back end already seems pretty high up.
http://picasaweb.google.co.uk/lh/photo/7bmkdvlu5fXapWd7ph5H-Q?feat=directlink
hmmm?
'78 P200E, 2009 TMax, 2009 S150
You gottta cut the frame a little
From past experience with a P200(w/ electric starter) in a 74 rally and a P200 motor in a 74 super, you will have to cut the frame a little to clear the air box. Cut off only about 1 inch high by 3 to 4 inches long, so there is no rubbing.
We used a dremel tool with a metal cut off blade, took about 2 minutes and then hit it with a little sander pad to smooth the rough sharp edge off.
You can put a little paint on it to keep the bare metal from rusting if you like.
No more rubbing.
@scooterraton avatar
2 - Many
2 - Many
I don't know about cutting the frame but nice pipe!
@slick_89 avatar
@slick_89 avatar
Ah ha,
Thanks Chas/guys, I'll probably start that next week and report back.
ScooterRaton, yeah, it's a pretty mean......but really loud, I did'nt realise how antisocial it was going to be. Occasionally I wish I had stuck with the standard vespa exhaust especially when I consider the hassle I had with moving and changing the stand........but then again it's pretty swift nowadays:)
@tor2ga avatar
@tor2ga avatar
I can't see cutting the frame. I would rather bang a big dimple into the metal to give you the clearance. And spray a lot of anti-rust primer to protect the metal inside and out when you are done.
@t5bitza69 avatar
T5s
@t5bitza69 avatar
T5s
cut another extension bolt in half and fit it to your suspension itll lift the arse ... or you could cut the frame ... or fit a manifold and bigger carb and cut the panel ......... youll have a big prob if you want it leaving standard.... youve already started the road to ruin swapping the lump
@hjo avatar
@hjo avatar
@slick_89 avatar
@slick_89 avatar
Yeah hjo, I've got both of those correctly fitted. I can see when why you'd think they were missing tho.
@hjo avatar
@hjo avatar
it looks like the frame is sitting too low. could it be the shock is a shorter style?
the engine case / carb box are the same size on a sprint and vsx... i don't know about the shock mount, though... maybe a second spacer would help? (i agree with T5bitsa69). you shouldn't need to cut into the frame!
@gatekeep avatar
1974 Rally USA 200 1980 P200e
@gatekeep avatar
Is the box top rubbing or the backside of the box.
I read here somewhere that there is a smaller carb box tops for some carbs? Two diff. Tops for the same box.
Stay tuned for more comment. Before you start cutting things.
@slick_89 avatar
@slick_89 avatar
It's the backside (corner) of the box and the lid is exacerbating the situation due to the protruding rim.
I'll do what you say and hold fire with the hacksaw and hammer until we get a few more comments.
@slick_89 avatar
@slick_89 avatar
bump.......(hope that's allowed?)
I'll be trying to fix this tomorrow night, either by hacksaw or hammer, unless anyone has any other suggestions.....
Get a DellOrto 24/24 PHBL / PHBH side slide carb. You will need a manifold for it, longer choke cable, different throttle cable to make it work. I believe it will sit way lower with out clearance issues.
@hjo avatar
@hjo avatar
it has to be something with the shock.
@sean_s avatar
bunch "o" bikes
@sean_s avatar
bunch "o" bikes
I have P in my VLB, with a P shock/spacer/rubber mount and have no rubbing...even with a 250 pound drunk guy in a dress
sean.
1974 Rally 200, 1974 Rally 200 with sidecar, Vespacross bike
Do not use the the P-series shock spacer. It is making the carb hit the back of the frame because it is too jacked up. The P-series spacer is for a shock on a P-series frame. If you sit on the bike you'll see the carb box move away from the frame. Get a smaller spacer.
@slick_89 avatar
@slick_89 avatar
Problem solved mattgyver was right, I removed the extension from the shock, refitted it and the carb moved forward perfectly.
Here's the rear shock with the extension removed
http://picasaweb.google.co.uk/lh/photo/O_Hqy5wnroOvIeFgtJDeLA?feat=directlink
and the carb/frame gap I now have
http://picasaweb.google.co.uk/lh/photo/21oKvxaPtf2eRkvmSaX7oA?feat=directlink
and the rear height now
http://picasaweb.google.co.uk/lh/photo/j8DZz7mnU1DRDIqk9WmGrQ?feat=directlink
Thanks everone who chimed in [/i][/b]
[ Time: 0.1296s ][ Queries: 3 (0.0811s) ][ live ][ 343 ][ ThingOne ]
