2010 GTS Super 300ie 2006 Honda Metropolitans Blue & Red
Posts: 94 Location: Chesapeake, Virginia |
I have decided that I want a windscreen to go on my GTS 300 to help ease the wind off me when riding at higher speeds. Any all out preferences on which one would be best to help lessen the wind factor for highway riding? ScooterWest has the Faco Mid on sale now with free shipping. Any thoughts on that one or others to recommend? Thanks for the help
The Vespa branded shield has the best mounting hardware. The expansion bolts in the Faco can become stuck in the tubes and then, you've got a real problem on your hands. If you ever need to remove the headset for any reason (like changing a burned out headlight bulb), you will have to remove the windshield and mounting hardware. I had a Faco that did this and after several hours of fooling with it (myself and my neighbor who is a retired plumber) we had to cut the mounting post on the side that was stuck so we could remove the headset and get at the expansion bolt and remove it. The Vespa branded shield uses nylon expanders and will not stick like the metal ones on the Faco. I replaced the Faco with a Vespa. I posted this in another thread a few months ago and a couple of other people posted that they had experienced the same problem.
Posts: 4332 Location: Utah Valley |
RIP
Now that you mention it, yes, my tall Faco screen also took a bit of convincing before it would release. I hope to remember to use anti-seize or some sort of lubricant when I install it again for this winter...which leads to an answer to the OP: if all you want is less wind pressure on your torso, go with a Vespa flyscreen.
How tall are you? I'm 6' and found the midsize Faco funneled more wind toward my helmet (meaning, tons more noise) than the lower Vespa flyscreen. Plus, I think the Vespa screen looks a lot better on the GTS. If you, however, want a screen that's better for cold weather riding, consider a tall windscreen. In any event, don't ever just buy something because it is on sale. Items on sale usually don't sell well, and there might be a reason for it Also, if you buy locally, you might be able to get to try the screen on a short but meaningful test drive. I did (from Scooterwest) and found what I said above about the Faco midsize. |
Posts: 3720 Location: Babcock Ranch, Florida |
What would happen if you wrapped the expansion bolts with teflon plumbers thread tape? Would the bolts remove easily? Would they hold in the wells adequately?
Just thinking. |
RIP
Tor2ga wrote: What would happen if you wrapped the expansion bolts with teflon plumbers thread tape? Would the bolts remove easily? Would they hold in the wells adequately? Just thinking. |
I wouldn't wrap them with the teflon tape because it would probably guarantee that they will get stuck. The problem is when the center of the metal expansion bolt gets crimped when you tighten down the shield, the metal compresses and does not release easily when you loosen it like the nylon center that the Vespa uses. After several tightening cycles, the metal is more likely to stay compressed when tightened and becomes harder to release.
If you already have a Faco or you buy one knowing the potential problem with getting stuck, I would suggest that you use a lot of waterproof, wheel bearing grease on the expansion bolt. |
Posts: 605 Location: Tuscaloosa, Alabama |
My wife and I have Prima brand screens from Scooter Works and they are excellent. She has the mid size and it seems to do all that is needed for scooting.
Posts: 2956 Location: Florida |
louisq wrote: urbanmotorsparts $155 free delivery price point makes the Vespa OEM unbeatable! |
trowel and cuffs wrote: My wife and I have Prima brand screens from Scooter Works and they are excellent. She has the mid size and it seems to do all that is needed for scooting. |
Posts: 5707 Location: Santa Cruz California |
There have been lots of posts on windscreens. Avergaing over the comments, most seem to agree that the Vespa windscreen it the best.
I have the Vespa tall but cut it down to customize it just for me. Here's the link but there are many other posts on windscreens. Tall Vespa Windshield Cutdown... Best regards, Miguel |
Price quoted for a GTS is $189.00. This still considered a good deal"' I put in urbanmotorsparts and got sent to a seller on eBay. Just wanted to make sure this is the best deal. Thanks, Philip
They routinely list the same item at different prices on their Ebay site. Here's the same shield for $155 including shipping:
http://cgi.ebay.com/ebaymotors/VESPA-GTS-WINDSCREEN-KIT_W0QQitemZ180403905087QQcmdZViewItemQQptZOther_Vehicle_Parts?hash=item2a00e9223f&_trksid=p4506.c0.m245 I'm pretty sure that this is the tall screen and you can always cut it down if you want to make it smaller. |
Posts: 16295 Location: Toronto, Canada, Fort Lauderdale, Florida |
I absolutely love the Vespa fly screen. I find that it's shape and angles match the leg shield of the GTS perfectly. As well, it gets the wind off my chest so highway riding is easy.
Some questoins about different screens. Please understandt that I have never ridden with a windshield of any kind. What is the "fly" screen and how does it differ in effect from the other sizes. And speaking of other sizes, why would buy the large one and then cut it down. Is this a visibilty issue or an esthetic one? Thanks folks. I am a total newbie, having ridden now about 30 miles since 1964 when I last had a Vespa. My memories of then don't quite surpass the joy of my new to me 2008 GTS 250ie. Oh my.
PhilipG wrote: Some questoins about different screens. Please understandt that I have never ridden with a windshield of any kind. What is the "fly" screen and how does it differ in effect from the other sizes. And speaking of other sizes, why would buy the large one and then cut it down. Is this a visibilty issue or an esthetic one? Thanks folks. I am a total newbie, having ridden now about 30 miles since 1964 when I last had a Vespa. My memories of then don't quite surpass the joy of my new to me 2008 GTS 250ie. Oh my. Miguel |
Hello Miguel. Didn't mean to ignore your comment, I just don't really understand what a fly screen is. Are we talking about the very small one that seems to just cover the instrument cluster? Again, never having ridden ANYTHING with a with a wind screen on it-wasn't done in 1963, too sissy!-I have no history on how much anything helps. I just got my Vespa three days ago and am trying to learn. Thanks for the info. Philip
2013 Yamaha Majesty / 2008 Vespa GTS (sold)
Posts: 329 Location: Emporia, KS |
Benito wrote: I absolutely love the Vespa fly screen. I find that it's shape and angles match the leg shield of the GTS perfectly. As well, it gets the wind off my chest so highway riding is easy. |
The flyscreen is the smallest windscreen. Typically it is about 8" at the top above the headlight or so. Aesthetically I find it to be the best looking, but it also improves performance of your scooter by improving your aerodynamics. You will find it to be one of the least expensive of the performance mods you can do. You will accelerate a bit faster and your top end will be slighter greater. No better bang for your buck. (well except losing a pile of weight)
PhilipG wrote: Some questoins about different screens. Please understandt that I have never ridden with a windshield of any kind. What is the "fly" screen and how does it differ in effect from the other sizes. And speaking of other sizes, why would buy the large one and then cut it down. Is this a visibilty issue or an esthetic one? Thanks folks. I am a total newbie, having ridden now about 30 miles since 1964 when I last had a Vespa. My memories of then don't quite surpass the joy of my new to me 2008 GTS 250ie. Oh my. |
Quote: "The small ones don't keep the wind off your chest and the tall ones act like big, wobbly sails." ⚠️ Last edited by XLR8 on UTC; edited 1 time
I'm with you XLR8. I have tall windscreens on both my bikes and have never experienced the "sailing" folks talk about. I ride above 60 mph in traffic, in wind and all alone and just don't feel anything not expected.
RIP
I have an un-cut Vespa tall screen on my GTV and this weekend I put nearly 300 50MPH+ miles on it with wind and never noticed any 'sail' or 'kite' effect at all -- even when passing oncoming 18 wheelers.
The think the 'sail effect' is more of a hypothesis by some rather than a proven fact. |
I have the tall FACO windscreen, and love it. Reduced wind noise and buffeting, and no noticeable wobble at speed, even when passing/being passed. I haven't ever tried to remove it, and the other posts make me a little concerned. I suspect you can drive out the barbed pieces from the back, or use a "slap-hammer", though.
The best thing about the windscreen, though, is protection from bugs at speed. You wouldn't believe the size of some of the critters I clean off! They would have ended up in my face (or mouth). I had a flyscreen on a previous scooter (LXV) and I didn't find it to be very useful. Lots of people like them, though, and they certainly look better. |
Gobshite Shiva
Posts: 14960 Location: London UK |
the sail effect might not be a problem on vespas, or for people posting in this thread, but it is not a hypothesis: http://2strokebuzz.com/2006/10/26/get-well-soon-poc-renae
consider the variables at work: rider experience, their weight and upper body strength, size and weight of the scooter, average speed, conditions, etc.... all of these make a difference in how you cope with a tall screen. i'm lightly built and of medium height. i love the wind-free environment created by a tall screen for riding in town but i'm not happy with it at highway speeds (120kph). gusts and strong crosswinds are tiring and annoying to deal with, and i've had to react quickly on more than one occasion to the feeling that someone had suddenly grabbed the handlebars and pulled them sharply away from me. all this to say that each of us can only speculate on what might work best for someone else. if you're not sure what to buy, i'd go with a tall screen to see if you like it, and cut it down if you don't. |
RIP
shankhill wrote: You wouldn't believe the size of some of the critters I clean off! They would have ended up in my face (or mouth). |
Agreed. However, they also hit you in the neck and chest. Haven't hit a bird yet, but I think I would be grateful for the tall screen under those circumstances.
BMW F700GS, 1996 Honda Helix, Giallo GTS (sold), Buddy125
Posts: 493 Location: Mission Hills, San Diego CA |
I must have done 50 different seraches for faco mid size screen and nothing came up about it getting stuck in the head set
Anyhow, I have this screen, and I do like it. I feel like a slice through the wind, and it really stabilized the bike at higher speeds. I suppose any mid size could do this though. Peronally I hate fly screens. See if you can try a bike with one installed first. They look nice but the air flow hits me all wrong. |
Willow Rouge: Excaliber Silver MP3 250 VIN 3288
Posts: 1093 Location: Austin, Texas |
I recommend pjparts.com I love their Fabbri screens. Just ask them, they'll recommend exactly what will fit well and look good...Their prices are very good.
Posts: 4213 Location: San Diego |
Its a Faco
I bought the Faco midsize from Motorsports (scooterwest) and because I am mechanically challenged, they installed it for me. I like it.
I took my first long ride today, a 140 round trip down a twisty highway to see my dad. I got headed back too late, and hit the twilight and evening bugs.....surely a flyscreen/windshield will help with this, right? My jacket looks like an insect massacre!
I picked up a Faco mid-size screen last week and it was incredibly noisy - being 6' tall, it put all the air into my helmet, making it impossible to ride with the visor open, even at low speed.
I swapped if for a Vespa Flyscreen, which I'm still a little undecided on it. It puts the air right at my neck - which I don't mind so much, seeing as it takes most of the air of my chest. I have it set at it's highest setting but am not sure if adjusting the height a few millimeters will actually make a difference. Anyone have experience with this issue? |
Posts: 3311 Location: Tortola, BVI (Caribbean) |
I have cut down (to eye level), tall Vespa wind screens on all three of my scooters. I am 5'2, female and 55 years of age. I do not have a lot of upper body strength, but I am not a weakling either. I am built like the average grandmotherly type.
I customarily ride in 20 to 30 mph winds and have ridden (recently) in 48 mph winds. I have never had even the slightest problem with my windscreen acting like a sail. Head on, cross winds, tailwinds ... no problem. When in Toronto in July, I rode WOT about 15 miles straight (on a very quiet side road north of the city) at top speed just to see what the scooter could do. I was hitting 72 (indicated) on a slight downhill grade with a tailwind of about 10 mph and the windscreen held up fine. |
Sharky 150 wrote: I picked up a Faco mid-size screen last week and it was incredibly noisy - being 6' tall, it put all the air into my helmet, making it impossible to ride with the visor open, even at low speed. I swapped if for a Vespa Flyscreen, which I'm still a little undecided on it. It puts the air right at my neck - which I don't mind so much, seeing as it takes most of the air of my chest. I have it set at it's highest setting but am not sure if adjusting the height a few millimeters will actually make a difference. Anyone have experience with this issue? The tall windscreens also provide protection from the wind for both of your hands-something I'm sure would come in handy in your neck of the woods. You can purchase the tall windscreen and always cut it down to fit you. There are a ton or really good posts here describing that process. My last suggestion is to SERIOUSLY consider buying the Vespa brand screen. It's sturdier and the mounting hardware is far superior to all the off-brand screens I have inspected. IMHO it's worth the extra few dollars. Good luck. |
