PKs 75 Gran Turismo 200
I have seen some correspondence on thsi topic; it appears to be a not-so-well-though-out engineering issue. I opened the head yesterday and dug deep into the display. I see a little connector under the digital clock but have no idea what to do at that point to get to the battery or replace the clock if required. I wonder if somebody can provide input.
Most folk decide replacing the battery is more of a PITA than they care to contemplate. Use your watch...
However, dismantling the dash into leetle bitsy pieces will get you there eventually - but at cost to future reliability?
Why the hell they didn't just wire it into the 12V feed who knows.
Aloha and welcome to the forum. Forget about the clock as jim has said it is a real PIA. I have a battery you can have Laughing emoticon Bought one for my LT and figured out how long it was going to take and said screw it. Who needs to know what time it is when your out enjoying your ride Good luck if you do decide to change it out.
⚠️ Last edited by judy on UTC; edited 1 time
GTS 250ie YELLOW N WHITE,Giallo Lime
So, how long did your clock battery last?
years or months? I sold my ET4 after 5
years and the clock was still working by
the time I sold it in 2008. Good luck on
replacing it, Judy has the battery for you. 8)
@silver_streak avatar
Here is the thread describing my adventures changing the clock battery on my LX (same inane design on the GT, I believe):
What on earth were those Piaggio engineers thinking...
It has a step-by-step description of what you have to go through to change the battery.
@en82pg avatar
2010 PIAGGIO BV 500ie Tourer
@en82pg avatar
Re: Battery Digital Clock Vespa Gran Turismo 200
Heading for 4 years on mine. So far, still ticking.
When it finally dies, I will wire in a small circuit to keep from having to change batteries ever again.
@jcwhitney avatar
Lambretta SX, Stella, Honda
@jcwhitney avatar
Have not seen the circuit but read the other posts on replacing the clock battery. Sounds like a pita. As long as you are undertaking the job of clock battery replacement, why not solder in a remote battery holder with a larger capacity battery for the clock? Just mount the new battery holder where there is easy access, as long as the battery voltage is the same there would be no need for additional regulators, resistors, or diodes.
[ Time: 0.0097s ][ Queries: 4 (0.0019s) ][ live ][ 343 ][ ThingOne ]
